Where to get SFI Dampener Pulley
Anyone know where I could get an SFI certified dampener pulley? Do all you 10 second and faster guys just use the stocker? I would like to make sure my car is up to snuff as far as the certifications go by next season and I am trying to find everything I can that I need. I dont have the rulebooks yet but it seems like i need a cage, window net, belts, fire extinguisher, fire jacket, dampener pulley and scattershield. Anyone know if I need a driveshaft loop or not? Thanks for any info!
Right now i am having the 10-point put in along with the window net. I dont know any specifics on the fire extinguisher so unless someone knows what I need and where to put it Ill just wait for the rulebooks. I also dont know what SFI level fire jacket I need, anyone know this for a 10.00-10.99? The scattershield I already have but cant seem to find anything about the pulley and dont know if I need a driveshaft loop or not. I also need it to be both NHRA and IHRA legal. Thanks again
Hey, ISP Racing has/had an ATI damper that's SFI approved. I don't know any specs beyond that. The way I've read it is, anything faster the 10.99, it's required. Here is the quick rules http://www.nhra.com/tech_specs/ETQuickRef.html
It seems as though you have a grasp on what's needed to run. Most people I see just think a cage is needed. Luckily it's 9.99 or fast for chassis ceritifcation.
Something else I read, which not sure if it's true, in 2006 sport compact running 11.99 or faster needs to have an engine diaper.
Good luck on the hunt, if I find anything else I'll let you know. I need to get a rule book for myself, they aren't that expensive.
Ivan
Ivan
I found that NHRA put the 2006 Sport Compact rule book online.
http://www.nhrasportcompact.com/2006...pact_rules.zip
tx evo
34
Nov 26, 2003 12:58 PM
