Few important Questions regarding GT35R
Old Dec 5, 2005 | 09:51 AM
  #31
4ringturncoat's Avatar
Originally Posted by Whoosh
Not to be a d---, but if you can show me an Evo with a GT35R making "great power" at 10 psi, I'll eat the whole car bumper to bumper.
I run a very conservative "street tune". I'm not sure what you consider a "perfect setup" but I will tell you that when I go to the strip and run c16, I can add timing and make more power.
Umm I am pretty sure he meant from 10 psi up, not @ 10psi max. Check out a comp chart and see how much a stock turbo flows and then a 35r, I know I would take 35r any day.
Old Dec 5, 2005 | 10:39 AM
  #32
nickracer9's Avatar
geoff is most likely talking about the hondas. I've seen anywhere from 300whp-400whp from the 35r on pumpgas with 10-12psi. the b series motor is hard to beat. alot more efficient then the 4g63.
Old Dec 5, 2005 | 10:43 AM
  #33
Whoosh's Avatar
I'm with you on the 35R. That's why I have one on my car, but I can promise you, it's not making great power at 10 psi. Even at 21 it runs awesome, but it really starts making BIG power from 25 psi up.
Old Dec 5, 2005 | 11:16 AM
  #34
scott88vr6's Avatar
Didn't you use to have a 3076? How did you like it?
Old Dec 5, 2005 | 11:30 AM
  #35
Whoosh's Avatar
It never made the power I was looking for. I also expected a little quicker spool. Much happier with the 35R!!!!
Old Dec 5, 2005 | 01:25 PM
  #36
TwStDeVo's Avatar
how much difference is there between the 3076r and 35r in spool? i live in a high elevation area so my choices right now are the 3076r and evo9-20g, unless the 35r can work up here. no matter what i chose, i will only be running 91oct and alky.
Old Dec 5, 2005 | 02:00 PM
  #37
Whoosh's Avatar
Just way too many variables for me to answer that question, particularly in your case (high altitude and we-wee gas). For me here in Texas, there was just a few hundred rpm's difference. Plus, at the same rpm, the 35 is pushing a significant amount more air. For me and my mods, tune, tuner, etc. there is only one choice and that's the GT35R.
Old Dec 5, 2005 | 04:26 PM
  #38
smokedmustang's Avatar
Whoosh, you have some great info. Stock head and internals? different intake manifold (magnus sheetmetal)? keep the great info flowing!
Old Dec 5, 2005 | 05:23 PM
  #39
TopLevelPerformance's Avatar
Originally Posted by rraulston
i think the Full-Race kit looks quite good......HHHmmmmmm
+ 1 Geoff and those guys at Full-Race make good products
Old Dec 5, 2005 | 05:36 PM
  #40
Wicked looking exhaust manifold to say the least! It is a sweet set-up!
Old Dec 5, 2005 | 05:58 PM
  #41
FLAEVO's Avatar
Smoked send me a pm,you said you were going to be down in the clearwater area in dec.
I have AMSGT35r,AMS intercooler,aem, use to be xede,264 272 hks,apr head studs,smc
alcohol,hard pipe,exede triple carbon (hd).I could take you for a ride and you can answer
all of your own questions.It is the least I can do seeing I got your soda from Andrew at
Dyno4mance.Tom
Old Dec 5, 2005 | 06:17 PM
  #42
TwStDeVo's Avatar
Dyno4mance.Tom
any dyno numbers on your set up? seems similar to what i might be looking to do and run pump and alky. whats your spool like?
  #43
I'm sure there is someplace, but not on an EVO!
Yea not An Evo, im sure he was talkin about the 35r itself being efficient from 10psi and up but on Hondas, as u see from there site and knowing about Geoff's products they specialize in Hondas as well
Old Dec 5, 2005 | 06:31 PM
  #44
FLAEVO's Avatar
With xede on dd 385 with 100% meth and 28psi. With aem 461 same boost on mustang
at CFT, people say it reads high so take the numbers with a grain of salt. The car feels a
little stronger, nose seams to stay up higher. Spool does not bother me,just pick the
right gear. Tom
Old Dec 5, 2005 | 06:45 PM
  #45
Dyno4mance.Tom
Yeah? I want my soda back too! I will pm you my number, and with the set-up you have, I will bring an extra set of underwear! See you soon.
Quick Reply: Few important Questions regarding GT35R
