GT35r - Oil/Coolant line sizes?
Just wanted to see what others are using for the oil and coolant feed/return lines.
I was figuring:
Coolant
-6 feed/return
Oil
-4 feed
-10 return
I was figuring:
Coolant
-6 feed/return
Oil
-4 feed
-10 return
Sorry to go slightly off topic here....but are you planning on using the .035 restrictor from ATP? Do you know what the EVO's oil pressure is (peak or general values at certain RPM's.)
IMO -6 coolant lines are fine/-4 feed line is fine/-10 return should be plenty. Good luck.
Louis
Louis
Louis
Louis
Let me know, i'm just curious as i'm coming from Subaru's that have almost notoriously high oil pressures. I'm pretty sure the EVO's are lower...just want some sort of numbers is all. Good luck.
Louis
Louis
WW-GSR
Jul 6, 2012 12:32 PM
sykou
Lancer Aftermarket Forced Induction Tech
Aug 4, 2008 10:17 PM
