Car boosting OVER 2.0 BAR , PLease Help me
Besides the explanation I gave you about the boost line being unplugged there are a couple of things that also could happen:
1) your actuator rod is very dry and rusted
2) your actuator rod got slighty bent during the collision repair
Search again for cut/broken boost/vacuum lines, you might not see the leak or the boost line unplug.
Also your solenoid could be bad/faulty as well. You could t-shoot your system with a boost controller, that is assuming you don't have a bad actuator.
By the way, I suggest you consider doing the diagnosis ASAP. I have melted the pistons on my Eclipses twice, put a hole in a piston once and again destroyed the stock turbo on a Eclipse by oveerboosting for having an unplug line.
I was lucky my turbo breakdown happened on the exhaust side, the turbine simply desintegrated in the exhaust breaking the shaft.
On my 91 Dodge stealth I completly destroyed both turbos once by overboosting them as well.
Be very very carefull, you have potential for breaking turbo and engine.
