ACD Article - Answers for everybody!
#136
#137
OK I'll add to this since this is about ACD (except mine includes AYC )
Got the dreaded 3 lights on early on .. jacked the car up, applied power to the pump .. relay clicked but pump didn't run (BTW pump is at the back on the left side under the boot.. and the AYC uses the same pump too) .. for ACD equipped cars only .. you'll see 2 holes that's covered .. those goes to the AYC (if you have it )
Took apart everything .. guess what .. @#($*@#%)$# pump is a DC brushed motor .. and all the carbon built up over the years has clogged the pump .. cleaned it up and its ok again ..
Tomorrow I'm going to see if we can get the armature or the brushes replaced ..
Geez .. freaking pump is like $1k from the dealer ..
fingers crossed .. Hopefully I can do something about it ..
#138
This is the ACD pump motor .. taken apart ..
this is the inside of the motor where the brush contact the armature
This is the culprit .. noteworthy is .. there IS A LIFESPAN to this ..
#143
He states in the article that '04 RS models came with a Viscous LSD. I read that Mitsubishi saved money with the production of the RS so they equipped it with a Helical LSD (Only on the RS model) leading to better handling. Is this true?
#144
Originally Posted by Terry S
When the Lancer Evolution VIII model was released in the US in the spring of 2003, the Evo was outfitted without the ACD or AYC found in other markets. Instead, it was outfitted with the Viscous Coupling Unit (VCU) which distributes the torque evenly (50:50) to the front and rear wheels. This VCU was also equipped on the 2004 model year Evo in both the standard and RS models. (2)
Terry S
#150
nice read up
off topic
so what do fault codes 82 and 45 mean on the diagnostics check with regards to all 3 acd lights comin on now and then (not driving hard).
- steven
off topic
- steven
