MSD DIS-2 Launch Control
2nd person to show us this without actually launching. Bah, I guess I'll have to just go take a vid of me launching with the Dynoflash launch control.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
http://72.41.83.159/video/msd-lc-noretard.wmv
http://72.41.83.159/video/moroso-12-16-05.wmv
http://72.41.83.159/video/hialeah-12-17-05.wmv
Listen to the launch on those videos...
AL will not be offering anything close to this as far as I know. When I am done with all my testing I should be able launch and shift and still maintain 15+lbs of boost. All this while still on the stock ecu, jestr reflash, and maftpro
I was just talking about launching, not NLTS. I have a 2-step at 6k rpm that builds 10-12lbs of boost, and then allows me to launch more consistently and harder than ever before. Unfortunately, I can't go prove (or disprove) the improvement in 60' until the tracks re-open.
It works pretty well so far and is all I need. I NLTS the 2-3 and 3-4 anyway, but I don't plan on doing the 1-2.
Yes, I watched the videos, but no, I don't see any differences. I just saw the difference in boost and rpm being built, if that's what you meant. I did not see any positive occurences in the launches themselves. You haven't had enough chances to practice it and show what it can accomplish.
I'm incorrect? I really don't know what you're talking about now. I never said that the Dynoflash launch control that is NOW BEING USED by many people like myself (it's not in the future; it's already released) is the same as what you're doing. I'm just saying it's launch control at a preset rpm with boost being built in excess of 10psi. Your video shows launch control kicking in around 6k rpm and around 14-15psi (1 bar). What part was incorrect? I'm confused, because it is working better than my previous method, and that method gave me 1.66 60's.
Do you not hear the explosions??? This is a antilag system not a simple ignition or fuel cut. This is different to what I was using at the strip and at the autox. I have not yet used this at any event because I was going very rich when I launched which caused a bog. I figured the problems tonight and corrected it. Anti-lag and AL's Launch Control is different. This is what I will be using from now on to launch the car which should produce a better launch.
joeymia
38
Sep 5, 2007 05:08 AM
