Napa T-Bolt Clamp Listing | great tool
Ok so after getting frustrated trying to figure out what tbolt clamps to get I made this:
http://www.justchil.net/evo/part_lis...st_clamps.html
Please, If you duplcate this page leave my ads in I need this to pay for hosting.
If there are any errors I will fix them. I will also add other clamps that I find.
http://www.justchil.net/evo/part_lis...lt_clamps.html
Originally Posted by razorlab
so all those sizes are needed to replace all the IC clamps on the evo?
No. These are all the different sizes I could find on NAPA's website. I believe most of the IC piping is 2.5" with the exception of the throttle body and turbo air inlet.. which I believe is 2.75.
I need to order a complete set so when I figure out exactly what I need I'll add that to the "chart".
I'm going to use the spring tbolt type on the TB and turbo inlet.
Adding some exhaust clamps now.. If my boredom keeps up I'll have every clamp you could ever need on this list before too long.
Edit: Found bandclamps too! Added a bunch of them.
Ok I'm going to order a bunch of different clamps to see which fit the best / I like the best. I'm going to try to get a spring clamp and tbolt clamp for everything.
Here is my list so far. Once I know 100% what fits I'll update my first post.
If anyone knows the size of the clamp that goes on the turbo end of the buschur lower ic pipe please let me know. I'm guess it looks about 2" (it's the smallest looking one in the pic. https://secure.buschurracing.com/cat...VOLOWERIC1.jpg
BOV Hose on upper IC (need exact size)
3 - 7051503 0.81 - 1.75 1.13 - 1.75 $3.99 (spring)
3 - 7051504 1.06 - 1.63 1.38 - 1.63 $4.19 (spring)
Throttle Body
1 - 7051508 SPRING $5.19
1 - 7051509 SPRING $5.29
1 - 7051532 2.50 TBOLT $3.39
1 - 7051533 3.00 TBOLT $3.79
Rest of Upper IC
2 - 7051508 SPRING $5.19
2 - 7051532 2.50 TBOLT $3.39
Lower IC
6 - 7051508 SPRING $5.19
6 - 7051532 2.50 TBOLT $3.39
1 - For turbo to ic pipe (not sure of size) TBOLT
1 - For turbo to ic pipe (not sure of size) SPRING
Throttle Body
Rest of Upper IC
Lower IC
