IC Coupler Size?
IC Coupler Size?
I'm planning on getting the Injen Intake with Upper IC Pipe but did some searching and learned that it reuses the factory flex coupler to attach the ic pipe to the ic. I want to replace that connection with silicon while I'm under there. I need to know what size hose I need. I'm thinking its a 2.5" 45 degree elbow but I'm not sure. Any help guys?
EDIT: I'd like to know the lenght I need, inside diameter needed, and what degree bend I need. Its a stock ic by the way.
Why change it? It works like a champ and you can't see it anyway. I JUST did the Injen intake/UICP combo and re-used the coupler you're talking about. Unless you have an aftermarket bumper where you can see it, why mess with it? It gets the job done just the same if not better than anything you'll find or make. My suggestion, leave it.
