clutch noises
clutch noises
I read here that performance clutches make a lot of noise, I would say transmit more noise from the drivetrain. I can't understand why.
Why the stock clutch is almost noise free?
I was near to buy a carbon clutch, but read that it makes gear rattle.
I was near to buy the exedy twin, but read that it makes a lot of clutch chatter.
I decided then to buy a nice organic clutch with a lightweight flywheel, but read that lightened flywheels make that gear rattle sound when you are off the throttle in a high gear (decelerating). Is it true?
I test drove an Evo with a performance clutch and man, when I was off the throttle in a high gear this car made a horrible clutch noise, I think it is called gear rattle, like triturating a metallic part, but the throttle response was awesome!!! I think due to a lighweight flywheel.
My objective: To have that awesome throttle response without that noise. Is it possible?
Just go with a single disc clutch and you will be fine. Those noises come from having more than one clutch disc in there. Some multiplate clutch noises are more profound than others.
The twin disc rattle only occurs when the clutch is in from the floater plates rattling. Gear rattle (noise) can also occur on twin and other clutches from lack of sufficient dampening.
The gear noise happens from having inadequate dampening of the torsional vibrations. These vibrations (rotational pulses) get dampened out from the weight of the flywheel and the springs in the center of the disc. If you are really concerned with the noise use a heavier flywheel (stock or ACT Streetlite) and a spring centered organic disc (OE center, not cheap aftermarket). FYI: The later stock discs use a Exedy WAD (wide angle damper) design to help keep it more quiet, but this is not something I would recommend for performance applications.
Originally Posted by mikiblueeyes
RPS carbon has 0 noise -just like stock.
The RPS carbon uses solid center discs which means that there will be gear noise too (decel, idle rattle, etc) typical of non-dampened discs. That is one of the tradeoffs for the lighter discs.
Originally Posted by k270kmh
What do you think about a MR clutch with ACT streetlite flywheel?
Originally Posted by ACTman
The MR clutch is going to be quieter than the others, but it is not what I would use for performance. There is no improvement in torque capacity or durability (which has been a real problem on the EVO). The lighter flywheel will give you slightly better revs and better durability because it is thicker but ultimately I would like to see a better friction material used at least.
See this. This is all smarts Just get an ACT and call it a day. best bang for buck. And Best for stock turbo w/ mods. Awesome combo. I had ACT in all my cars and never would go back. There a good name. And i use them Always in the cars that i mod at our shop
Originally Posted by Silver05Bullet
Listen to ACT man he knows what hes talking about
also if the noise bothers you, turn the radio up
ACTman always comes here to help us, thank you again ACTman!
The last thing I would do is to turn the radio on to hide a bad noise from my car.
To tell you the truth, I never listen to the radio, the exhaust note is better.
tsidrift1
12
Jan 4, 2017 02:10 PM
shotgun_joshy
15
Apr 15, 2011 01:21 AM
TitanMotorsport
Oct 22, 2009 11:09 AM
evosevengsr
May 20, 2004 02:51 AM
