42R Boost Levels
42R Boost Levels
Does anyone know the max boost that a GT42R turbo can handle, before it starts to be inefficient? It seems that a GT30R runs out of juice at around 30 psi, GT35R maxes out at around 35-37 psi, etc....
So my theory of the number after GT is equivelant to the max boost level of the turbine wheel...planned or only a coinsidence?
Originally Posted by scott88vr6
I believe people are running around 40-42 psi with GT42R's
This would go along with my theory...that really well put together combos can run a little more boost than the number after the GT__.
Originally Posted by EVOONYOASS
Not to go off topic, but Shep is running upwards of 50+ psi. What turbo is he using? GT47?
my friend has a 91' talon w/ a gt35 on it and put down 760awhp @ 44psi before blowing a whole in the side of the block. imo its all about doing what is said cant be done. and thats how you make crazy power. so who cares where any given turbo is said to be "efficent" a gt35 is sapposed to only be good for 540awhp and he made that @ 33 psi.
Originally Posted by Ronin17
That's pretty unbelievable for a 65lb/min turbo. I am not saying I don't believe you, but it sounds a little far fetched.
i agree but i watched him do it 4th gear everything done just like normal, and i can honstly say if i didn't see w/ my own eyes i wouldn't believe it. the new turbo is a turbonetics 70 trim rated for like 7 somethimg hp so that should do the job.
Did your friend ever run the car before the dyno? What did he trap?
Originally Posted by Drifto
People make more hp than the stock turbo is suposedly capable of on paper so I don't see why It's not possible.
