EVO8 turbos converted to EVO9's and 20G's!!
#33
Originally Posted by Rcebowl
Dave..
For those with an 03 (or any new for that matter)
will we need/ would you suggest getting a new wastegate act?
it comes with a new wastegate actuator... the high pressure actuator is an upgrade that costs extra...
#34
The deals from buschur racing get better every day!
Matt55, I'm pretty sure it's another $175 for the high boost actuator. $950 + $175 install kit + $175 high boost WGA = $1300 for everything you need after you send in your good condition evo8 turbo.
#35
The lower i/c pipe we send in the install kit. It is the outlet pipe ONLY. We looked today and think that the stock lower pipe will work with our outlet pipe. I can't gaurantee it as I didn't try to install it but it looks right.
Someone here should be able to confirm this at this point in time, any help?
I forgot about the wastegate actuator. Crap. The actuator is not included in this. I can make a package kit out of it and supply an actuator with it. I will have to look into the cost.
David Buschur
www.buschurracing.com
David Buschur
#36
Originally Posted by davidbuschur
My car is at 388 whp and 393 ft lbs on race gas with this turbo on our dyno.
David Buschur
David Buschur
any idea what pump and alky numbers would be?
#37
Thanks Dave this is making the IX 20g ti/al looking more and more apealing you mention 388whp with this on your RS, I thought you where making this amount with the regular VIII turbo on race gas at least I think I remember you making around this amount.
#39
So basically does this work off of an exchange basis most people wouldnt be able to have their car down for that amount of time. Would the car come with the new boost actuator installed on the turbo if we elect for it. Otherwise we whould have are stock ev0 8 actuator. Is there any difference in the actuators from the evo 8 and evo 9 ?
#40
David Buschur
David Buschur
#41
#43
Originally Posted by Haehl
Any more info on your car as far as mods, boost level, and what not?
https://www.evolutionm.net/forums/sh...d.php?t=150510
#45
Great news.
We can now upgrade your GOOD condition EVO8 turbo into a EVO9 turbo when we build at 20G turbo.
For guys that already have the 20G-8's (EVO8 turbo with 20G compressor wheel) we can upgrade that too.
Here is how it works and the pricing:
Send in your good EVO8 turbocharger that is ALREADY equipped with the 20G wheel and we will upgrade it to the EVO9 compressor housing for $750.
Send in your good EVO8 turbocharger that is NOT equipped with the 20G wheel and we will upgrade it to the EVO9 20G for $950.
We can do these NOW. Just call and get an RA# before you ship us the turbo.
Thank you,
David Buschur
Thank you,
David Buschur
