EVO8 turbos converted to EVO9's and 20G's!!
#46
someone needs to chime in and let us know if the new outlet pipe works with the stock lowe i/c pipe. im still running the stock i/c and piping so b4 i put mine in it would be helpfull to know.
Originally Posted by davidbuschur
The lower i/c pipe we send in the install kit. It is the outlet pipe ONLY. We looked today and think that the stock lower pipe will work with our outlet pipe. I can't gaurantee it as I didn't try to install it but it looks right.
Someone here should be able to confirm this at this point in time, any help?
I forgot about the wastegate actuator. Crap. The actuator is not included in this. I can make a package kit out of it and supply an actuator with it. I will have to look into the cost.
David Buschur
www.buschurracing.com
David Buschur
#47
I believe it is just worded a little funny. The $750 isn't for a compressor cover upgrade. It is the entire new evo9 turbo with the 20g in exchange for the evo8 turbo with the 20g (for those that already upgraded their current VIII turbo). I could be wrong.
#48
So for those of us with a 9.8 exhaust housing, the price to upgrade is:
$950 20G-9 upgrade
$250 10.5 Hotside
$175 Install Kit
$1375 Total
To buy the 20G-9 and install it, the price is:
$1350 20G-9 Turbo
$175 Install Kit
$1525 Total
So for those of us with 03s and 04s we're probably better off buying the turbo outright. Just want to make sure those numbers are correct.
Thanks,
Paul
$950 20G-9 upgrade
$250 10.5 Hotside
$175 Install Kit
$1375 Total
$1350 20G-9 Turbo
$175 Install Kit
$1525 Total
Thanks,
Paul
#51
Here is the deal on the actuator. You do need an EVO9 actuator BUT that is not a problem and no extra charge. I do need your good EVO8 actuator when you send in your core, we can modify the actuator to work with the EVO9 turbo.
David Buschur
David Buschur
#53
Originally Posted by mustard
DB- Do you have a price for the IX 20G upgrade that would include the customer retaining the same core as was sent?
-Paul
#54
The turbo gets rebuilt. No you do not get your turbo back.
#55
Power difference between the EVO8 and EVO9 20G's is minimal, the only difference is the EVO9 turbo doesn't surge.
No problems running alcohol, the turbo doesn't care what you run through it.
$950 to convert your EVO8 to a EVO9 yes. The 10.5 housing is $250, correct. Seems like you just repeated what I wrote
The turbine housing is NOT included with this. You will be using whatever you have for a turbine housing now or you will have to buy a new 10.5 housing.
My car is at 388 whp and 393 ft lbs on race gas with this turbo on our dyno.
David Buschur
David Buschur
#57
$950 20G-9 upgrade
$250 10.5 Hotside
$175 Install Kit
$1375 Total
$1350 20G-9 Turbo
$175 Install Kit
$1525 Total
Thanks,
Paul
$950 20G-9 upgrade
$250 10.5 Hotside
$175 Install Kit
$1375 Total
$1350 20G-9 Turbo
$175 Install Kit
$1525 Total
Thanks,
Paul
What about the WGA? I didnt see it on your budget
Thanks,
Josh
#58
Originally Posted by vegeta irie
Could you clarify why us "little" turbo guys would benefit from buying the turbo outright instead of sending ours in?
Thanks,
Josh
Thanks,
Josh
And, as far as the WGA, it is included with the Evo9-20G and DB said he could modify the Evo 8 WGA to work with the turbo without extra charge.
-Paul
#60
David Buschur
David Buschur
