Exedy Hyper Single Clutch
I have and Exedy hyper single clutch with about 2000 miles on it. I find if I try and shift above 7k rpm I get complete and total lock-out. I've tried adjusting the clutch pedal and that didn't work. I was wondering if anyone else has had this problem? Could it be a bad clutch install? Thanks in advance!
It is mosly likely an install issue but there is no way to tell without taking it out. Check the splines on the disc to be sure they didn't get messed up when putting the trans. in.
Originally Posted by gonzo
Did Corey drop the ball again?
Ok, now this clutch seems to be going out already. WTF!!! I've launched on it not even half as many times as i did the stock. With the power I'm running to this clutch this should not happen. Anyone else have any issues with the clutch?
piciu82
Dec 23, 2016 10:25 AM
revvin9k
19
Feb 21, 2007 12:00 PM
Vivid Racing
Jul 11, 2006 01:08 PM
ku7484
Sep 9, 2004 03:18 PM
