GT3076R PeakBoost kit DD Dyno#'s
#33
Originally Posted by Toddevo 8
the 35r is good if you build the motor. you need to run more boost the have fun with the 35r.
about the alky question, I dont want to use it I dont think it is the way to go, you can run out of alky and them you are screwed, I have seen a few kit not work well. so for me it will be race gas.
#37
Originally Posted by Event-Horizon
I hate having to do this EVERYTIME to explain a DynoDynamics.
DynoDynamics Dyno's read lower than other Dyno's such as dynojets and dynopacks. They read similar to Mustang Dyno's. DD Dyno's are just more accurate and consistant than others and great for tuning.
For comparison, this evo would put down aprrox 425whp (93oct) on a Dynojet local to Atlanta.
Expect to see 100+ more whp on race gas (C12)
This is a very powerfull car to make 365atw's on a DD rolling road and its the one I trust
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
Mark
#38
it not if you run out of alky that can be the problem, I have seen a few kit not work well or not at all. so it is not worth the risk for why little you gain. I can just use race gas to make all the power I need.
thanks Mark for the input on the dd dyno
#41
Well I went out and looked at this kit becuase I have never heard of the company but I would like to say there are several things I really like about it so other people should consider.
1. The manifold, very nice and uses a large wastegate 44mm with vband.
2. The turbos look to use a true garrett 4 bolt housing.
3. The downpipe is two piece containing the O2 and downpipe area with vband clamps.
4. Looks to use stock water and oil lines.
Just alot of good things that other companys don't use. The kit looks great, If I was looking for one I would take into to a very high consideration. I am impressed.
#42
The turbos are a true garrett turbocharger. Peakboost Products are manufactured by Phoenixturbo.com. Phoenixturbo happens to be one of the largest garrett distributors in the united states.
The manifold as with all peakboost products utilizes nothing but the best. Downpipe is fully stainless, 2 piece with vband connection. Helps the ease of installation and provides a very clean unit.
The kit itself is the hottest thing out in our opinion.
AF-Performance
