Replace Head Gasket when upgrading head studs?
Originally Posted by GTVEVO
Just so you are aware a stock HG is 45bucks from your local dealer.
slightly off-topic question, are ARP head studs needed for cams?
Originally Posted by LilJapnBoy
my mistake....I tried looking up the part on mitsubishiparts.net but couldn't find it....I thought I'd heard OEM head gaskets being very $$ but I was taking a guess.
the new studs are an added safety measure
Originally Posted by use2vtec
Yes there have been several threads about it but they werent torquing the studs to the correct torque. Most of them were torqued at 70 but those of us who torqued them down to 85 have had no issues. There is a chance that it will work for you and maybe it wont. I think that it has worked for more than its failed.
EDIT: If you remove the head then you have to replace the headgasket, no way u can resue the stock one once the seal has been broken.
Isn't removing one stud at a time a bad practice when removing heads in general?
The reason I'm asking is that I recall from an engine class I took a few years ago that when you remove and reinstall the head, it has to be done a little at a time, in the same torqueing sequence in the service manual, or you risk warping the head.
I'll have to look it up in one of my old books.
Am I way off base here?
I don't think the low torque value has completely everything to do with the leak, I have seem stock motors leak with the correct torque value (85lbs) and I have seen fully built long blocks built by professional vendors push oil out the back as well with the same torque values. These motors perform flawlessly so I don't think it is the head stud problem when they are installed correctly. This is my reason for feeling its the stock HG design around the oil passages. Don't get me wrong the stock HG does very well compression wise, no complaints there at all it is just the oil leaks that happen for honestly no proven reason yet with it.
Originally Posted by superz
Actually I agree with you 100%. The stock HG leaking oil in the back is pretty damn common with Evos that have ARP studs or stock bolts. My theory is that the very high oil pressure that the Evos run causes the leak in the oil feed passage not the return which has no pressure. What I have tried and has worked is by spraying the stock HG with copper sealant spray, which adds an extra seal that has been working so far.
___whoosh___
May 8, 2009 02:44 PM
