ACD Problem!
sorry if i was ranting on last reply.....
anyway, check your transfer case oil, and see if it is really overfull, and if it has the atf mixed with it....i had one a few weeks ago, same issue....pulled the fill plug and it was way overfull with atf mixed in, so i order transfer case....waiting for customer to return for install
mitsitech, like i said i have no prob paying for inspection if the aftermarket part is at fault, and whether i pay or not, the tech still get paid by the dealer so i dont see what is the problem here.
Originally Posted by TurboTimah
i know a lot of 05 Evos have problems with the ACD whether it be bleeding the system or the 3 lights always going on.
From what you are saying, it seems like you have a leak somewhere ... hopefully its not in the TC as Mitsitech is suggusting... next time try to avoid some frustration by going to the dealer with your car troubles ... goodluck and let us know what happened ...
Have you seen some of the burn down EVO due to the active diff?? It's a serious problem. It may not be talked about that often but since we buy crashed EVO's I've seen a few come through here that are burned to the ground. Two of them being 05 MR's Scary **** if you ask me, and I own a 06 MR with a diff that’s starting to act funny around tight turns and No lights are going off??
I have the same thing when starting the car its one light a couple of seconds later on all 3 come up i still cant figure it out some guys say bleed the lines and it will work never tried it .
3 lights on.. this problem for mine DTC no line press
https://www.evolutionm.net/forums/sh...&postcount=138
I have a question for those of you who have had an ACD DTC set in your cars.
Did you ever check the fluid level and notice it was low? I'm not trying to accuse anyone here, just curious. I was looking over my car at around 10k miles and noticed the level in the ACD resevoir had dropped just below the Min mark. I topped it off and haven't had any problems so far (16k miles now).
Not sure where the fluid went. I haven't seen any leaks, and when I replaced my front diff. fluid at 15k miles it didn't appear to have any ATF contamination.
tlcoll1
Feb 24, 2018 10:06 AM
