Removing Transfer Case - NEED HELP
Originally Posted by damianhindley
Damn this guy (^) is good, thanks man, sounds much easier. So if all ihave to do is pull out the TC then this is the way to go. Also with your second way, would you need to remove the tail of the TC or does it come out as a whole unit, thanks again
I guess it's not like pulling the TC on a DSM at all.. Instead there is like a rod that you can't really see that comes off the TC and you need topull that back. Something along those lines from what I heard. Never done it, so don't take my word on that, but if someone investigates this, there might be an even easier way to getting that muffa outta there. :-)
you dont have to drop the subframe simply raise the engine by the front motor mount and that should give you more than enough room to pull out the transfer case make sure not to raise the front mount to much as not to mess up the radiator with the turbo on the car
this is the quickest and easiest way i believe, the only thing putting it back in requires 2 people
The front motor mount I assume is the one that goes on the front of the tranny. Not the passenger side or drivers side mount right?
edit...this thread is from january....
EVOlutionary
Dec 4, 2008 08:46 PM
GTB/ZR-1
Jun 23, 2007 08:05 PM
