ISC problems
Idle Speed Controller (ISC) Problems
After searching I couldn't find a conclusive answer on how to determine if your ISC is faulty or needs resetting.
I just noticed that the car is bogging down when the radiator fans comes on, further testing revealed that it does the same for the AC. I think the culprit is the ISC.
I read somewhere here that sometimes the ISC motor goes out of range and basically needs to be reset. How is that done?
I also read that I could just give it time to fix itself but what if the ISC is faulty? I might be waiting in vain. Is there a test to determine if the ISC is faulty?
Thanks in advance..................
