Quad turbo... Pics
#76
Originally Posted by o4whtevors
i saw some one state that 2 1000 cfm turbos would generate 2000 cfm. that statement is not correct. if you sit down and do the math ( not just basic 1+1=2 ) you would see that it does not work that way. in fact if you had 2 1000 cfm turbos doing the same amount of work at 20 psi you would only have about 1500 cfm available to you. the equasion is not lenier due to the resitance you are going to encounter. the same is true in pipe line cfm, two 1/2" pipes are not going to supply as much as one 1" will, infact the two 1/2" will be closer to one 3/4".
Two 1,000 cfm turbos should still be able to flow 2,000 cfm if the engine can reach high enough boost levels and/or RPM to swallow that much air.
#77
Originally Posted by SaabTuner
wtf? Two 1/2" pipes don't have the same cross-sectional area as a 1" pipe. That's why they won't flow as much. It has nothing to do with the CFM limit of a turbocharger.
Who the Fuc k cares!
#80
Anyway, just coming back on topic, does anyone know if Owen dev. have put it on to an actual car, or is it still a project engine. - i can't seem to get to their site right now...
#82
Originally Posted by stiguy
That looks pretty sweet. I wonder how much power that thing puts down.
#87
Originally Posted by x838nwy
Un-fu*king-believable.
I seem to recall that the mutiple turbo (per cylinder bank) setup's are attempts to reduce the lag caused by a large turbine (on large turbos) while spinning up. So while you _might_ make less power, you stand a much better chance of getting your power earlier and thus broadening your powerband. As far as I am aware, there's no reason why a single turbo should make more power than multiple turbos. Surely it's just a matter of flow and pressure development. If you have two turbos in parallel developing 20psi each flowing 1000cfm then that should be the same as one turbo at 20psi flowing 2000cfm(?). I'm ignoring a number of things (such as plumbing and dynamic effects) but I think that's pretty much the crux of it.
For V12 or even V16 engines, I guess the 4 turbo setup is probably advantageous cos it simplifies your exhaust manifold design....
I think it can only be a good thing jmartinez1170. You can use the time to learn to use punctuations. [monotone voice]You seem to type like Kimi Raikkonen talks yes. Is it intentional i don't know... [/monotone voice]
#89
this looks great but it will be impractical! its more of an example of the enginering work that owen is capable of! it has been widley pubisized over here inthe uk that this is a one off!
and can you imagine the cost of this kit?????? it would be exspensive!
Chris.
Chris.
raytrix
Oct 28, 2010 07:10 PM
