BG synchromesh vs. pennzoil sychromesh
Originally Posted by EvoG8r
I had a $7000 experience with Pennzoil. I use BG... Lokey Mitsu in Clearwater, FL sells it for $9.XX per bottle.
o wow...9 a bottle!? damn thats cheap!!
I went from Pennzoil to BG. But I got BGII, the synthetic kind. Both were very similar for the first couple months of having it in, however, Pennzoil's lubricancy (word?) got lost after about 2 months of usage. It felt like stock again. I currently still run BGII right now and it's lasted 5 months with no degredation so far (in terms of shifting feel). They both shift like **** on a cold morning though, but only for like 10minutes. I'm also one of those ones who have a 2nd gear grinding issue, and no...neither of them fixed the problem (it helped a little bit only).
Overall, Pennzoil is cheap, but make sure you change it out VERY often, cuz it breaks down quick (I guess the cheapness would be offsetted by how many times you have to pay someone to replace the fluid, unless you do it yourself). They say BGII is supposed to last some ridiculous amount of time, like 30k miles on average, simply cuz its synthetic.
AWSOME!!!! JUST WAT I WAS LOOKING FOR!!! thanks soo much man!!
Yea, 3qts is all you need. It may seem like you're gonna run out as you pour it in, but as long as you don't accidently spill any trying to fill it up, you should be right on the money with 3qts.
Do not use Pennzoil. I had it tested after my tranny exploded. The oil had broken down and burnt. It was 2 weeks old, but this happened at the track in 90+ degree weather after several hard runs. The car didn't actually have any problems until the next day when I was merging on the interstate after work.
The other issue was that the mechanic actually put Pennzoil in my transfer case (like a DSM). So I blew my transfer case as well. Thankfully, it was covered under a special insurance coverage (mechanical breakdown) from GEICO so I only spent $1000 on upgraded parts and the rest was covered by insurance.
Since then I have used BG and have never had problems. It's been to the track 3 times since that happened to me in summer of 2004. Also, I would recommend Dynaqueen (sp?) from Mitsu for your transfer case. I'm posting this from learning the hard way.
Tried Pennzoil...didn't like it...went back to dynaqueen.
The Pennzoil syncromesh viscosity seems a little thin and needs to be change often since its non-synthetic and breaks down quicker. After 5000 miles mine looked dark and a little 'watery'. Yes, it does improve shifting, but I'm leary of how well the pennzoil is protecting the transfer case gears over time?
