Weird Boost Spike
Originally Posted by Girlie
Did you make sure that the bleed hole is clean on the UNOS? After watching the video, even after 2 flashes it was still evident. After Al cleaned it, it went away and stayed nice and flat for the remaining pulls. Al even made a comment about after the first pull when he cleaned it. Just want to make sure it's not something that can be easily fixed for ya..
Girlie
Girlie
well i have the hallman MBC so i dont think it applies to me
Girlie
Could it be a Hallman+IX thing...? How was Joshd's when he had your Hallman Clay?
Girlie
Girlie
Joshd posted a chart with the turbosmart MBC, Chris had the Forge. Both had the same mail in flash. One had a double spike like me(Forge user) the other no double spike but a taper issue. I would think that the problem lies in the MBC more than anything else. Maybe someone else running a Hallman could chime in on this.
Girlie
Girlie
what i dont understand i had the same MBC on my 05 EVO 8 and i didnt have that problem
MBC's have a hard time keeping boost steady with the cam timing changes.
Girlie
yeh that s what i figured, it s a timing issue, i know the car is knocking duriong that double spike, form the log i have done, so i hope with some ecu tuning it will solve the problem. if not i ll have to try that forge UNOS MBC
Wow, Girlie, that is exactly what Chris's boost looks like on the dyno.
Chris, have you cleaned out the bleed hole on the MBC already?
I have not touched the MBC in ~800 miles. When I had it open it looked perfectly clean to me....
I am going to try to find someone at Mitsubishi Racing to see what they are doing to the IXs. I suspect it has something to do with the MIVEC, back pressure, and rate of boost change (but that is just an uneducated guess) and the affects to the MBC.
I WISH Buschur had some ideas.....I have 100% confidence that he'll know what is going on ....Maybe with your new partnership you can get his $0.02....Hope all is well in Colorado.
Girlie
Girlie
How did Al clean the MBC? Did he use just compressed air or a cleaner? Is this a problem we will have to constantly deal with? Thanks for the graphs....
Originally Posted by cij911
Girlie,
Chris - after seeing girlie's plot, which looks exactly like yours, we clearly need to clean out your Forge MBC.
My latest plot doesn't show a double spike because of the extreme smoothing, but I do see it on the road. I've seen it to a greater or lesser extent with all of the controllers I've used. The Forge was just the worst.
I think there is enough data here to show that MBCs do have a harder time controlling boost on the IX ... however, I'm still not convinced that a little tightening of the wastegate actuator won't help things a bit.
Also - chris ... you don't really want 21psi at redline on the stock turbo with stock exhaust. I don't have the compressor map, but I'd be willing to bet that it would be out of it's effeciency range. 18-19psi is probably something better to shoot for ... I'm only 3+ psi off
By the way, I think you should be the first one to buy the EBC and let us know how it works
Al uses a the little tool you clean a torch tip with. And like Clay said, it's just the bleed hole, not the insides with the spring and ball.
Girlie
