Weird Boost Spike
Old Feb 27, 2006, 03:11 AM
  #31
cij911's Avatar
You guys rock!!!!! I am trying to contact Mike@FORGE and see if he'll give me the step by steps or better yet, send me one that is perfect ......
As for EBC, I am very interested. If I had the BR exhaust, do you think I could hold 21 psi to redline? Or is the turbo only capable of pushing ~18 psi at redline (if so, no need to go EBC route just yet). Thanks again....
Old Feb 27, 2006, 05:30 AM
  #32
joshd's Avatar
Originally Posted by cij911
YIf I had the BR exhaust, do you think I could hold 21 psi to redline? Or is the turbo only capable of pushing ~18 psi at redline (if so, no need to go EBC route just yet). Thanks again....
I would have to defer to the experts on this, but it just seems a little high for the stocker at redline. I suppose the only way to know for sure without the compressor map is to gradually bump it up and watch the hp on a dyno ... when you raise a pound of boost, you should get somewhere around 10hp gain. If you turn up the boost and barely see any gain, or a loss ... you know you're at the limit
Sincy we're going down this path of potentially trying out an EBC ... which one is considered the best? HKS EVC, APEX'i AVCR, Blitz SBC-iD, or???
Before I go this route though, I'm going to get the Hallman or a clean Forge unit back in and also tighten my wastegate actuator. That should happen this week if I can find time ...
Old Feb 27, 2006, 06:18 AM
  #33
Warrtalon's Avatar
Chris, MIke@Forge is on a cruise for 10-11 day starting today, so he won't be in touch. If you want the instructions, just search for the thread that Al started when he explained all of this. It has the instructions on what to do...
Old Feb 27, 2006, 07:12 AM
  #34
joshd's Avatar
Martin over at TheSpeedFactor is also very familiar with the cleaning process ... as I believe he cleaned mine thoroughly until it worked and then relayed the procedure to Mike@Forge.
Old Feb 27, 2006, 07:38 AM
  #35
Girlie's Avatar
I have full BR exhaust and only get 19psi at redline. So holding 21 is doubtful. Honestly, I have yet to see a IX hold 21psi to redline. (assuming pump gas psi)
Girlie
shiftndeesgears
12
Mar 30, 2009 11:44 AM
JuancaROD
163
Apr 13, 2007 07:12 AM
d3wu
Nov 13, 2006 02:33 PM
nixx
Feb 13, 2006 08:20 PM
masterevo
Feb 28, 2004 12:21 PM
Quick Reply: Weird Boost Spike
