MR Tranny's! Any Grinding Issues?
The Evo 5 speed has been plagued with Synchro issues since its inception. So I am wondering if the MR six-speed is suffering from the same tranny issue. From what I have seen in prior threads most of the grinding complaints are from the 5 speed tranny.If the MR is not plagued by this issue I will likely get an MR over a GSR. But if not that 4000-6000 dollars savings GSR/RS are hard to overlook w/o a great reason. This qualifies iMO.
Bump
https://www.evolutionm.net/forums/sh...light=MR+grind
I came across this thread while searching the same subject. You know, its wierd situations like these that get me paranoid about buying another evo, especially since I already got my tranny/tcase fixed.
MR owners speak up.
MR owners speak up.
My MR tranny has been fine, it shifts as smooth as the first day. But when the weather is VERY cold, my 1-2 synchro will grind if I try to shift too fast but this goes away after the tranny fluid warms up (which take a while) and then it starts shifting smoothly (as stated in the manual). I just have to remember to shift very smoothly and slowly until the fluid warms up. On warmed weathers its rediculously smooth
Hope that helps.
Nice to see you have been un-banned
Hope that helps.
Its not exactly a grind. Its just notchy. And only during grandma/normal driving shifts. When I shift fast at high RPM its butter baby.
I think its the double synchros trying to line up at low speeds. No damage will result, and Ive read changing the fluid does wonders. BG Synchromesh did amazing things with eclipse trannies, and those have got to be one of the notchiest transmissions Ive ever felt. Ive only got <4500 miles on mine, but Ill be changing my fluid to BG Syncromesh II (synthetic). This would also help with the cold fluid complaints.
They new GSRs have zero issues with trannies. They have all the updated Syncros. Plus it shifts rock solid.
The MR has teflon-lined cables, so I think it's even smoother than the 5 speed. I have a slight notchiness in the morning going 1-2, but it disappears after about 3 minutes. I have 25,000 miles on my MR and I like it much better than the 5 speed. I drove my dad's STi last weekend, and the MR shifter is light years beyond his. Personally, I think the MR is worth it. I'd say the Ape should get an MR
Pretty ironic and fate I guess. Always been called an MR and now I will be driving one.LOL
its no honda shifter, but i'm definately impressed wth the 6 speed. I've grinded it a couple downshifting to first before its warmed up, but normally the shifts are pretty solid. 1200miles so far. Sometimes it seems to lock me out of 6th? but it hasnt been doing that lately.
