how much more power would TD06-20g 8cm housing put out vs. stock turbo?
I'm considering getting a TD06-20g with 8cm housing, just wondering if it is much different in terms of:
- max hp, max torque
- power band
- spool up time
than the standard evo 6 TME turbo?
Any comments please? Thank you
- power band
- spool up time
I have made a million threads about this turbo kit.....so...you can see what I made previously and what I made on the new kit, because that was the only change.
problem with saying how much more would it put out compared to the stocker is that the stocker is rverse rotation and the 20g is standard, so you need to change manifold, lower intercooler pipe, etc.
Those changes can add hp over stock.
We saw almost an 80hp difference going to the 20g, full boost by 4k, a wide power band, and 343ft-lbs of torque.
Ben
Ben
boomtown
83
Feb 2, 2022 03:58 PM
