stock main bolt torque??
You want to torque them to 52 lb/ft. in a 18, 36, 52 sequence... Do it from the middle out, alternating from side to side as you progress to the outside, similar to a head stud torqe sequence... I'm assembling a motor myself currently at school, I go to Wyotech. If you need anything else I would be more than happy to help. Feel free to e-mail or pm me... you can check out my motor here...
http://www.ratemyevo.com/member/Sean...ember=SeanJohn
Actually the last torque is done to 18ft/lbs and then mark the bolts with a line of paint and turn them all 90 degrees further. Use motor oil on the bolt threads. That's the way the manual say to do it.
I would love to see the manual you are reading....
Dont worry about alignment. The girdle will self align when ran. Both torque methods work fine. The 90 degree method eliminates thread friction problems. You an torque to 52 but 10 can easily be lost to threads binding. If your assembly is clean you wont have a problem.
If you want a set of the Evo manuals in book form Jon from TRE www.teamrip.com has them in stock, they are about $225 but very well work it. It is a 3 book set and is very through.
krisshono
Jul 24, 2012 05:58 AM
AWD Motorsports
Sep 23, 2011 09:46 AM
JSC Speed
Evo 'For Sale' Engine Internals and Drivetrain
Oct 31, 2008 09:16 AM
d3wu
11
Apr 8, 2005 11:34 PM
silverEVO8
24
Jul 9, 2004 09:34 AM
