What happened here?
Old Mar 9, 2006 | 11:49 PM
shiv@vishnu's Avatar
Question What happened here?
2 runs. Three different perspectives. Guess what happened on run #51 (blue run)
WHP and Torque
WHP and Boost
WHP and AFR
Old Mar 9, 2006 | 11:50 PM
housedj's Avatar
blew off an I/C hose...
Old Mar 9, 2006 | 11:51 PM
EvoallovEr's Avatar
Dynoflash
Old Mar 10, 2006 | 12:18 AM
TrinaBabe's Avatar
Fuel pump quit, injector failed, or ran out of gas.
Old Mar 10, 2006 | 12:52 AM
Thunder-rush's Avatar
You are testing the new feature of xede, lean condition or defined varible= shutdown 10psi of boost. Bet 1$ on $1,000...!
Old Mar 10, 2006 | 01:30 AM
Evo_Jay's Avatar
I think this.....
OR this......
BUT, this is fu(kin funny....
Originally Posted by EvoallovEr
Dynoflash
Old Mar 10, 2006 | 01:39 AM
TrinaBabe's Avatar
I guess looking back at the static wastegate pressure the whole testing of the lean -> boost cut feature makes sense
Old Mar 10, 2006 | 04:00 AM
WarmPepsi's Avatar
i dunno, and it's really not my business, but why in the hell would the guy runnin the show, stay on it for another 1500 rpms, when obviously something is wrong?
that defeats the common sense factor
edit: i mean, i realize you guys are out to prove a point, but still.
Old Mar 10, 2006 | 04:42 AM
sgplancer's Avatar
+1
Old Mar 10, 2006 | 05:22 AM
forum04pl's Avatar
Dynoflash
Old Mar 10, 2006 | 06:36 AM
Smogrunner's Avatar
That must be your new lean-run protection system on your Xede. What did you do to make it go lean? Did you just pull a bunch of fuel at around 4400rpm to see if it would work?
Old Mar 10, 2006 | 07:07 AM
jj_008's Avatar
Definitely, the lean run protect. That seemed to work pretty quickly.
Old Mar 10, 2006 | 07:09 AM
Ludikraut's Avatar
Meth kit ran out of meth and the new lean-run protect kicked in on the XEDE.
l8r)
Old Mar 10, 2006 | 09:11 AM
Awww... what you said is true. And you will the easter candy. Jut PM me your address and well send it to you.
However, what you are seeing is a little bit more than just a drop in boost. The info provided by the graphs is enough to tell what else happened.
As for how the leanrun was induced, that's simple. I just had someone yank off the boost line that goes to the fuel pressure regulator in the middle of a dyno pull . This resulted in an immediate 20psi drop in fuel pressure. In any other situation, that would have caused engine failure. How's that for being confident in a product?
shiv
Old Mar 10, 2006 | 09:13 AM
Light's Avatar
nice feature....
