Oil too thin, ticking.
I recently changed my oil to mobil 1 full synthetic 10w-30 and it was ok.
I let the car sit for a week in really cold weather like 20's and then i go to drive today and it ticks pretty decently. It doesnt sound like its coming from the head but i can't tell..
I think i am gonna run it some more to see if it just needs some oil ran through it after sitting for a week...
If that doesnt work im going back to conventional oil not synthetic. I think it's too thin ..
I also have 58000 miles..
I think that if you haven't figure it out by now you shouldn't worry, the ticking noise on the 4G63 is perhaps legendary .
No matter how old, new, beat up,and type of shyntetic oil you use these engines make the noise randomly once in a while on cold or hot weather.
My .2c
Carlos
My .2c
Carlos
Originally Posted by C6C6CH3vo
10w-30 M1, esp in fridgid Ut, is in no way a thin oil. Read your owner manual for the weight and temp. Thin is 5w
Did the ticking just start recently and you never heard it before for the past 60K miles?
My .2c
Carlos
My .2c
Carlos
your lifters probably drained out of oil or something.
ticking sound is never a good sound of anything. it could be many things, but it's usually have to do with valves or rod bearing.
throw some stp syn additives to thicken the oil.
that or take the ignition system out, crank the car for 3 sec intervals, it may help bleed the lifters.
i don't know.
i don't know.
i have ticking, i didnt even notice it till someone pointed it out, i didnt notice because ive had it from stock, its not bad maybe it will get worse when i get cams, ive been putting in 10w-30 oil since stock.
Hassan
103
Aug 5, 2023 11:37 AM
