Can you swap an "MR 6-Speed" tranny in an 03' evo?
Apparently, TRE knows how to do it. Why not contact them?
http://www.teamrip.com/Evolution.html
I don't think you can add the ACD, though - it will have to use your existing center diff.
In order to install the MR 6 speed, you would need:
6 speed gearbox
6 speed shifter
6 speed cables
Right side transmission mount
MR center console (the 5 speed console interferes with shifting into reverse)
MR shift boot
MR shift knob
This setup will bolt up to your 03 transfer case, but now would be a great time to upgrade to a Quaife front diff. In my opinion, the cost of upgrading to ACD is not worth it for the added bling of switching between tarmac, gravel and snow.
The ratios are a LOT nicer than the 5 speed in the higher gears.
6 speed gearbox
6 speed shifter
6 speed cables
MR shift boot
MR shift knob
Registered User
6 speed gearbox
6 speed shifter
6 speed cables
MR shift boot
MR shift knob
6 speed gearbox
6 speed shifter
6 speed cables
MR shift boot
MR shift knob
Winston
Yes it is. There is a guy selling a TRE built 6 speed tranny with all the necessary conversion parts here:
https://www.evolutionm.net/forums/sh...d.php?t=175688
