Ignition Problems
Old Mar 23, 2006 | 10:10 AM
mxjs's Avatar
Ignition Problems
Does anyone else have ingniton problems. I've already had to replace the coilpacks twice and the wires, plus i've had to change spark plugs at least 5 times. Right now I'm runnin NGK Iridium #9 with magnacore wires and HKS DLI and i started misfiring again. If anyone has/had this problem I'd like hear about what you did to fix it. Thanks
Old Mar 23, 2006 | 10:26 AM
BURNALL_4's Avatar
make sure the wires clip down on the plugs the was they should you may have to open them up w/ a screwdriver. ive heard of problems w/ magnacore wires not "clicking" onto the plugs like there supposed to.
Old Mar 23, 2006 | 10:58 AM
SwiftEVO's Avatar
What temp plug are you running? 9?
--Josh
Old Mar 23, 2006 | 11:00 AM
bluebanana23's Avatar
switch out the wires to the stockers and your plugs may be too cold
Old Mar 23, 2006 | 11:02 AM
ttmanta05's Avatar
Get rid of those magnacore wires. I had nothing but problems with mine. Switched back to stock and the problems are gone
eve-slow's Avatar
Try some NGKs.
Old Mar 23, 2006 | 11:08 AM
mxjs's Avatar
So go back to the stock wires. I went with the NGK BPR9EIX and the can ran great for 2 months now it misses all the time.
Old Mar 23, 2006 | 11:09 AM
lancealott's Avatar
One of my friends kept having problems with his coilpacks and linked it to a problem with a turbo timer. Thats the best I can give you.
Old Mar 23, 2006 | 11:16 AM
SwiftEVO's Avatar
Thats too cold of a plug. Try running 8's.
--Josh
Old Mar 23, 2006 | 11:23 AM
mxjs's Avatar
I switched to 9 because i had problems w/the 7s & 8s. I'm on my third set of coilpacks, Mitsu even had to replace the piston rings.
okevolutionVIII
Jun 17, 2017 07:21 PM
Ferp
Jul 11, 2016 09:07 PM
reil_neil
Jun 10, 2015 05:31 PM
IonNinja
Aug 5, 2006 12:28 AM
EVO8speed
May 5, 2005 11:58 AM
