Head Flow Data Comparison
Given the recent release of Cosworth's new cylinder head, I thought it might be interesting to make a rough comparison of head flow data. I used Cosworth's data for the stock head, their head, and inserted Buschur's data from the percentage improvements at various lifts as claimed by Buschur. I could not insert AMS' data because I don't have it.
This is intended for purposes of discussion only, so don't take this as gospel. It's just a thumbnail sketch that is only as accurate as the data used.
right.... I'm not aware of any cams that have that lift either.
The point I was trying to make was the cams that advertise "high lift", like Revolver, have no benefit on a stock head. My bad, should have been more specific. A 10.xx mm lift cam should be plenty good for a stock head.
Originally Posted by Ted B
AFAIK, there are no EVO cams with that much (0.5") lift.
Actually, it appears flow begins to drop off on both the Int and Exh sides around .30" lift (7.6mm)on a stock head.
mrfred
Sep 14, 2022 07:08 PM
