US Only Oil Filters? What gives?
I've bought two new Evos since last August--an '8' and then an MR '9'. They both came from the factory with oil filter part #MD356000. But the only replacement filter from the dealer is MZ690116. The parts guy says this is listed as a 'US Only' filter. Why do we get a different one and is MD356000 better? Thanks, David Dicks
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
Why would you use an OEM filter anyway?
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
I've been using Fram filters for 35 years but I learned in August that there was a big screwup with Fram filters and EVO's. The filter they had been recommending was pulled from distribution. I talked with a rep back in August and he said the new filter was 'under deveopment.' Turbos usually have higher pressure oiling systems than other engines and the filter requires a higher 'burst pressure.' It's not something you want to fool around with. Until I find something different that's recommended by people 'in the know', I'm sticking with the factory OEM filters. But which one?
Fram.
Fram has some problems but you can get a better filter than OEM for less. Do a search for oil filter test on google and read read read. This is a good one.
http://minimopar.knizefamily.net/oilfilterstudy.html
That's helpful. Thank you. I will read it carefully. The problem is that just because a company makes pretty good filters generally......it doesn't follow that they will necessarily be good for EVO's. In this case, Fram's problems are a case in point. I think what we need is guys that have been racing these. That's certainly a 'worst case scenario'. Anyway, does anyone have any idea why the US gets a different filter than worldwide? I really don't care what filters cost. I've always thought it was false economy to save a few bucks on a filter....or oil.....on a car that costs many thousands of dollars.
chapter8
14
Feb 21, 2005 09:22 PM
tpm17
Nov 20, 2004 05:20 PM
