Cat or not to cat
Old Apr 2, 2006 | 12:20 AM
  #31
Dr. SS's Avatar
Originally Posted by nj1266
Is your Megan test pipe 3 inch on the inside of the resonated area? I got an LPI test pipe and it was 3 inch at the mouth and 2.5 inch in the resonated area.
yep internal diameter on the test pipe is a full 3"
Old Apr 2, 2006 | 08:43 AM
  #32
Silk's Avatar
Originally Posted by evo-licious
I've seen an electronic cel fix by Perrin. I've also seen the "GP Moto Oxygen Sensor Adaptor CEL Fix" which basically puts the O2 sensor out of the exhaust flow. I'm assuming the one from Perrin is better.
No, a mechanical fix is better. They work and you dont have to hack up any wiring
Old Apr 2, 2006 | 09:30 AM
  #33
BigAeVo's Avatar
i have the buschur racing cel fix no problems so far.
Old Apr 11, 2006 | 12:47 PM
  #34
nj1266's Avatar
Does it have a bung in it for a wideband O2 sensor? Where did you get one from?
Old Apr 11, 2006 | 02:38 PM
  #35
BOOSTEZ's Avatar
You will tell a performance difference with a Hi-flo cat and TP. I have both and just recently switched to my TP..I can clearly tell at high end.. not so much down low though. I also have a resonated test pipe and the sound is very throaty, but not loud.. It sounds the same when driving in traffic.
-M
Old Apr 11, 2006 | 08:29 PM
  #36
VRSF Tiago's Avatar
It's less environmentally friendly, but I've noticed the difference between a high flow cat and a catless test pipe before on a few turbo cars. You'll notice the noise as well as the butt dyno as well as turbo response.
Swapping them out when it comes time to pass emmissions/inspection sure is a ***** though.
Old Apr 12, 2006 | 04:09 PM
  #37
ZimDoc's Avatar
Test Pipe. Only 5% of the polution in the US is caused by Car/trucks. Go nuts and burn that fuel!!!!
Old Apr 12, 2006 | 05:29 PM
  #38
sonicnofadz's Avatar
I just switched from no cat, to the ultimate racing high flow 3 inch cat, then back to my perrin 3 inch test pipe (emissions testing). I noticed no difference in sound what so ever. I did notice a slight increase in power though, along with exhaust soot at high rpms
Old Apr 12, 2006 | 05:39 PM
  #39
Ph3n1x's Avatar
Test Pipe baby. Its like wearing a condom. It better without it .
Old Apr 12, 2006 | 08:09 PM
  #40
mcwop23's Avatar
so far so good on my catless buschur TBE, not even that loud, no fumes in the car.
and no CEL
Old Apr 12, 2006 | 08:34 PM
  #41
BigAeVo's Avatar
what kind of testpipe fits with the hks catback/helix downpipe anyone have this setup im sure most testpipes will fit but i just wanna make sure.
Old Apr 12, 2006 | 08:38 PM
  #42
sleet's Avatar
Just go catless, its more fun.
Old Apr 12, 2006 | 08:45 PM
  #43
silverEVO8's Avatar
I'm going to be putting a TBE on my '05 Evo, and can't decide if I should go with a 3" free flow cat or cat delete pipe. I don't mind having to put the stock cat back on to get emissions. I'm just curious how much more HP I will get with the cat delete pipe. If it's not significant then I will just go with a free flow cat to save the hassle each year at emissions time.
I had the test pipe in my EVO VIII but I could not tell you if it made more power or not. I never dynoed before and after.... However, if you want to do that, I've got a nice 3" B&B DP with a bung welded for the WB O2 sensor and a matching TP with the CEL fix that I can sell you for a very good price . I've gone completely back to stock with my MR.........
Old Apr 13, 2006 | 08:09 PM
  #44
calvin's Avatar
i have that setup and use a helix test pipe...fits fine, just be sure to loosen the dp bolts then tighten from the front of the car to the rear when installing...i am taking mine off though, too damn loud, my ears ring when i get out of the car...i just ordered the ur high flow
Old Apr 13, 2006 | 08:22 PM
  #45
alloyic_rs's Avatar
^^ Tell us how the UR high flow is when you get it. I'm thinkin of getting it when i getta downpipe.
jym89709
Oct 25, 2011 12:09 AM
sdfontanini
E85 / Ethanol
Apr 1, 2009 09:07 PM
hoola47
Lancer Engine Tech
11
Sep 12, 2008 05:22 PM
Mr. Stock
Sep 27, 2005 05:41 AM
bluebanana23
Jul 14, 2004 04:42 PM
Quick Reply: Cat or not to cat
