J&S safeguard
J&S safeguard
have u guys used a J&S safeguard? I was wondering how good they are at sensing detonation and pulling timing; they use the stock knock sensor, right? would it be a good idea to add or upgrade to a better knock sensor?
http://www.jandssafeguard.com/
i was thinkinga getting the monitor and having it hooked up to a wideband sensor as well
Well, you know that the stock ECU already has this built-in. Were you talking about using it with a standalone ECU or something else?
I had one on my FD... with a car like that, it should have been a factory piece.
The J&S - I believe - has a much more precise knock sensor (if not include then available) and will pull timing if it senses detonation.
Never popped my FD motor due to detonation - so it seemed to work well for me... additionally, it doubled as a Wideband O2 - and at the time, there were very few WB O2s with a 52mm gauge available... shoot the AEM EMS wasn't even on the market at this time... wow - that was a long time ago...
Aaaaaanyhow, a tad expensive - a healty tune might be more valuable on a 4G63... but just my .02.
fwiw, the stock knock sensor is tuned to the motor and should do better than anything not also tuned to the motor.
I wonder what happens to those people who put cams in and keep the stock ecu. Since the noise has changed it would seem they will be getting or could be getting false knock detection.
Doesn't the AEM use the stock knock circuit? With Hydra you have a map that you can "tune" the stock knock sensor sensitivity with.
I would not bother with the J&S unless you are going with a standalone system that does not offer knock sensor support.
Originally Posted by Zeus
Edited my comment above... but really, it has saved many a B18C5...
I currently have been using HKS's Knock/Amp which also doubles as a wideband. Nothing like listening to the motor thru headphones.
