Stay stock plugs or go 1 or 2 step colder?
#31
Originally Posted by Tonz of fun
Hey your qoute says 1575 and you can have 300 whp email how warr.
#32
As Schuyler said, the link is right there in my sig above the thing that says $1575=300whp. It's called the Warrtalon/Buschur package, and that one is for Evo VIIIs (03-05). Click on the link for all the details of the package and how to order it (call Buschur Racing).
Once again the A.D.D. Blinded me. I didnt see the hyperlink sorry for wastin your time...
#35
dbdude - where did you see that.. I was looking for it too.. I saw that it should be >.08 of recommended... and also w/mods <.02-.05.. Please let me know(ANYONE), I was wondering myself
#36
Originally Posted by dbdude
The NGK website says to gap the BPR7ES at 0.032. Same for the iridiums.
I have an LM-1 on my car and I get misfire spikes even though the ECU does not give me a check engine light.
Our stock ignition system is maxed out. Add 1-2 psi and you will get misfires. The car will run great, but you are getting a "blown spark" every now and then.
I have been battling this for a whole month now. It is no big deal, but the car will be even more perfect if I can eliminate this.
I have gapped my plugs down to 0.025 and still get the "blown spark" misfire. With the mods you have, you probably have this as well. Gap your plugs down to 0.026.
#37
I had an advice from NGK to stay with stock instead of going to BPR7EIX.
Why are the stock plugs considered bad?
The stock plugs were developed specially for the Evo technical engine specification, weren't they?
#39
#40
Originally Posted by evilevo8
how come the manual says the standard value for sparkplug gap specs are:
mm. (in.)1.0 - 1.1 (0.039 - 0.043)
#41
wow this thread went big. So on the concept of boost. So the reading coming from my mitsu boost gauge is really off ive heard this a lot so if it is then i couldnt tell ya how much im pushing
#43
Originally Posted by 3K
If your running the stock iridium plugs you can probably get away with 7-10k before changing them, depending on their condition and how your car's running. If your using copper plugs I would change them at every oil change.
#44
Hmm, I just checked and I thought I was running BPR7EIXs but I am actually running BPR6EIX somehow, is this really terrible? I have some used BPR7ES I guess I could regap and put back in until I get a new set of BPR7ES/BPR7EIX...
Advice on the BPR6EIX, not sure how I got them as I thought I ordered trhe BPR7EIXs... I did not check my order and just threw them in...
