SBR GT3076R turbo kit
Old May 5, 2006, 09:53 AM
  #31
Turbojunkie's Avatar
sbr 35r kit
guys, ive got this kit and not only does it look sweat but deliveres great power. i have only a dyno flash and piggy back safc2 for tuning and netted over 440 whp at 27 psi. it would have been more like 470-490 whp but my base tune was done on pump and 92 oct so the timming and all is conserative. i wish now that i would have had my custom tune done on 110 oct. at anyrate, after long consideration of all the kits out their this one did exactly what they said it would do. and the 02 bolts up to the stock dp loction like it was built by mitshi themsevles. fitment it bar none the best. great price too. i get mad compliments at the track about the manifold. anyway i give it a thumbs up. walking away from a corvette in 4th gear at 27 psi is way too much fun
Old May 5, 2006, 09:54 AM
  #32
SuperHatch's Avatar
Since I know I'm not the only one that was having a damn near impossible time seeing the 30r graph....
Old May 5, 2006, 10:11 AM
  #33
evo 8 ya's Avatar
why does it say "flywheel torque" and "flywheel power"? Isn't it suposed to be 405WHP?
Old May 5, 2006, 10:25 AM
  #34
staatz's Avatar
Dynapack reads like that but its at the wheels .XXtunings' dynapack in East Hartford Ct does the same.
Old May 5, 2006, 12:37 PM
  #35
gsujeff55's Avatar
that wastegate dump return isn't too close to the turbo? it looks as if its too close and even at an angle that its blowing air TOWARDs the turbo a tad.
Old May 6, 2006, 08:04 AM
  #36
Levar's Avatar
Stock Turbo Numbers In Signature
Originally Posted by joeymia
very nice looking kit... which turbos do you offer for it?
Brother.
Are those stock turbo numbers in your signature or are they using this turbo kit? I like how you have both types of dyno sheets in your signature. I believe that everyone should do the same to eliminate some of the drama between Mustang numbes versus the various types of other dynos.
Old May 8, 2006, 08:52 AM
  #37
nrcooled's Avatar
To use a Dynapack dyno you have to remove the wheels so it's says flywheel HP but reads very similar to a "stingy" dynojet. My stroker/stock turbo setup made 340hp 340lb/ft on a dynapack.
The good thing is dynapacks have very repeatable/consistant numbers which is the only reason you should use a dyno in the first place.
Old May 8, 2006, 09:14 AM
  #38
SlowboyMR's Avatar
Exactly ;-)
mark
SBR
Old May 24, 2006, 02:45 PM
  #39
SlowboyMR's Avatar
http://www.slowboyracing.com/more.php?id=5875&
posting the link to the site so everyone can see the full kit, options and all..
contact me directly for an EVOm small price break!!!
mas@slowboyracing.com or call in 724-349-8417 ext 12
Mark
SBR
Old May 24, 2006, 03:08 PM
  #40
funnyclub's Avatar
Is there another pipe needed to bolt up to the intercooler.
Old May 24, 2006, 04:06 PM
  #41
AlwaysinBoost's Avatar
The kit looks very nice. I noticed there was no price difference between a 30r & 35r. Is that correct or just a mis-print?
Mark
SBR
Old May 25, 2006, 06:35 AM
  #42
SlowboyMR's Avatar
no.. the lower intercooler pipe with silicone is supplied. Obviously there is differences in company FMICs and may need tweaked to fit a particular core.
ALWAYSINBOOST, yes the price is the same for the kits.
Mark
SBR
Old May 25, 2006, 06:51 AM
  #43
evo_007's Avatar
Will this kit work with the factory airbox? I would like to keep the OEM airbox and maf.
Old May 25, 2006, 07:48 AM
  #44
SlowboyMR's Avatar
no, it will work with the factory maf, but you need a filter adp. The Air box takes up to much room and wont fit with the piping. Besides it would be rather restrictive to run an air box with an upgraded turbo
Mark
SBR
Old May 25, 2006, 07:58 AM
  #45
evo_007's Avatar
I'm in CA. I would be willing to sacrifice a bit of efficiency to retain the stock airbox. Your kit may be able to pass a visual inspection, but not with the CAI. Would you guys be able to fab up a pipe/hose to fit the stock airbox?
Quick Reply: SBR GT3076R turbo kit
