Vishnu vs Buschur and Al.......I LOSE!!!
Originally Posted by EvoTio
Your thread title is inviting trouble. As for running 110 octane on your 93 octane map, you are defintely not getting the most out of your car. The A/F ratio can be leaner, and your boost level can be upped to run better with the higher octane.
it doesn't matter who tuned who... your car should be faster but it is not. Obviously your tune needs some improvement. Even with a "safe" tune you should be trapping 114 or over. I suggest getting something like MAFTpro so you don't have to depend on other people everytime you add/change something.
Btw, smoked, I was assuming you raised the boost when adding the 110. Did you not even do that? There's no reason to toss in 110 if you're not raising the boost. You definitely won't run as well with 110 with no change in AFRs or boost unless your pump gas tune is already knock prone and pulling timing. You'll be rocking out after you get the meth tune, because it will have the AFRs and boost optimized for max power. I expect 115+ traps.
Yeah, you just see the Vishnu guys responding. It's not full of Buschur/Dynoflash guys taking the opportunity to jump on something that isn't really there.
Smokedmustang, believe me, your mods are fine and could run 11s all day, especially on race gas, but everything needs to be put together properly, the tune needs to be right, and the driving needs to be superb. Even your buddy ran a good bit slower than expected for his mods, so this isn't an example of Shiv vs Buschur really. It's just you not being a big drag racer, and your buddy driving a little bit better. No biggie. I know the guys don't want me to reference the time in my sig.
I dont know...look and assess the whole picture...the guy just telling his observation.. only fanatic people would start such flame.
Originally Posted by Eclipsed Evo
I agree. The only thing this thread is going to do is start a flame war once again.
let me get this straight...
1. you changed a bunch of things on your car, didn't get a retune to optimize the changes.
2. you are not that great at dragracing.
3. you race a friend who could be a faster driver than you
4. your friend's tune IS optimized for his mods
5. you think it is because of your flash?
I think you need to get reflashed.
I can bring this to light pretty easily.
I tuned that pump map on your car, Kevin (or tried) at Dyno4mance last year. The carbon clutch you had at the time was slipping like crazy, so in the end, we actually backed your car off to 304whp and reduced the boost, because the midrange torque was overwhelming that fried (or misinstalled) clutch. Its a super conservative tune, with low boost, conservative timing, and rich fueling.
I assume you've got the clutch problem rectified now?
When Shiv remaps your car on pump gas and methanol at the STL dyno day, it will do a lot better (provided you have the clutch problem fixed).
As others have said, adding race gas to an already conservative pump tune without increasing timing, leaning the fueling, and/or raising the boost will not make the power the car could.
Try again post dyno day and post results!
Originally Posted by smokedmustang
Sweet with the Meth power...................but..........a.....No I didn't do squat to the boost tables. By next tuesday, I will put race gas in, and flip the 110 leaded map Shiv did a while ago. I will see what he does at the Dyno at the end of the month. Dyno, then the following Tuesday, DRag with the same guy, and we will trade cars for a pass or 2!
With the TME, the boost will be a lot higher. Just use the pump map you're using until Shiv can remap the car. I had to reduce your boost tables when the car first came in the dyno since you had changed the turbo.
Running leaded race gas on a pump gas map will kill power. It'll run too rich and even misfire at times up top. It is not unusual to see a 15-30whp loss in this situation. Rerun the car on pump gas and she how she does.
If you want to run race gas, make sure you are running a race gas map. This is especially true if you want to run leaded race gas. Because to make power that that stuff, you *need* to lean out your fuel map in a big way. As well as add in a few degrees of timing and as much boost as you can give it (with stock turbo). But frankly, we don't even recommend leaded gas as it is too hard on the ignition system. Best gas we've found so far for all-around use is MS109 unleaded.
A TME set-up, tuned for race gas, will trap in the 116-118mph range. Maybe another mph or two with a big fat spray of meth.
-shiv
-shiv
P.S. I'm not sure if it's been posted, but hypothetically Warrtalon crushes the both of you. lol I'm not sackriding, merely comparing 'mods and times'
Which, BTW, is 100% due to YMMV
Originally Posted by Noize
DO NOT!!!
I will re-re report this in a month, stay tuned!
