Exedy Twin disk SD or HD?
#32
Originally Posted by TTP Engineering
We have them for $1499 shipped for the HD - new higher torque model!
#36
quick question as far as parts go all i need for a clutch install other then the clutch is the throw out bearing right? anything else i need before i take it to get installed.
#37
#39
Originally Posted by SuperHatch
It is recommended to replace the flywheel bolts at the time of install. A lot of people reuse them, but I wouldn't. Also get yourself some lock-tite for the flywheel bolts and PP bolts. Some neverseize for the input shaft and TOB/clutch fork pivot points wouldn't hurt either.
is that a preference thing? my clutch is fine right now, but when time comes do places replace those and do that? im planning on going to ttp....
#41
it seems like i can never get an answer to my question about this clutch,everytime i ask i get nothing.So i,ll try again.I had the sd excedy twin in my 03 and want to know if the HD still has the same decel noise and is there any chattering on a normal take off(engagement) Can someone who uses this cluth PLEASE give me an answer i,d appreciate it, Thanks
#42
#44
