knock link controller?
Old Jan 29, 2007 | 04:33 PM
Pd1's Avatar
Pd1
It's times like these when I really miss DSMLink. It would turn on the CEL if the ECU detected knock counts beyond a user-specified amount (and turned off the CEL when the counts dropped below that amount). Using ECUFlash alone, this may not even be physically possible, but it was certainly a fantastic feature to have on DSMLink.
Old Feb 8, 2007 | 04:38 PM
yesevo's Avatar
more info on knock link plz~
Old Feb 8, 2007 | 05:46 PM
jbrown's Avatar
Originally Posted by sparky
I bought mine w/o the dedicated knock sensor, so ended up hooking it up to factory knock sensor wire, behind the glove box. Overall it's an easy install.
Same here, it works really well. I pulled mine apart and flush-mounted mine from behind right above the gauge cluster. Just drilled holes for the LEDs to poke through. You can't tell it's there unless it lights up.
Live4Redline
Jul 17, 2024 08:09 AM
jaredh
Mar 23, 2013 04:39 PM
ArtofRalli
May 9, 2011 10:37 PM
HermaN
Jul 7, 2010 02:22 PM
acamus
Oct 24, 2008 07:22 AM
Quick Reply: knock link controller?
