RnR (Daily Driver) HITS THE DYNO!!!!
Old May 8, 2006, 03:05 PM
RnR Racing's Avatar
Guys, we finally got my daily driven Evo on the dyno. Most of you who have been around a while know this was the 1st ever 2.4 EVO in the US. We have been delayed tuning our current set-up because our Tuner that worked for our shop Darwin stopped tuning cars a while back.
Anyway we have been working with Alfred from TT and we are really happy with his EMS tuning abilities. We took the car up there yesterday to use his dyno and have him do some magic on the EMS.
After a very short period of time we have the running on wastegate spring 22PSI. I couldn't believe at 22psi we were making
609whp at only 27psi
At this power level the car was still barely tuned and had a ton more left in it at this boost level. So I thought great we can easily make 750whp at 38psi, but I was wrong. At only 22psi the 1000cc injectors were completely maxed out. I am sure the duty cycle is well over 100% and we couldn't physically add anymore fuel into the AEM fuel map.
So we are going back to TT this week with our new AEM injector driver and 1600cc injectors. We plan on running 38psi and making close to 750whp in our daily driven street car. Here is a short list of mods on our car.
RnR GT37R Turbo Kit
RnR Fully Built 2.4
RnR Stage 5 Head
Tomei Springs and Retainers
Tomei 280's
RnR Big Plenum Intake Manifold
Accufab 75mm throttle body
3"Alum IC Piping, Silicon Hoses,T-bolts
1000cc injectors, Big Fuel Rail, AN Fittings everywhere
Aeromotive 1000HP Fuel Pump, Aero Regulator
-10 AN Feed line, -8AN Return Line, AN Fittings at all locations
AEM EMS
AEM Wide Band 02
Gauges(Boost, Oil, Water)
Short Shifter
RnR Big Race 26x12x4 FMIC Kit
Tial BOV
4"Cold Air Intake w/Filter
COP Ignition w/MSD DIS-2
TRE Transmission
RPS Twin Carbon Clutch
SS Braided Clutch line
3"02 Turbo Back, HKS Carbon/TI Muffler(Street)
4"Turbo Back (Track days)
5 point Roll Cage(NHRA Legal/Removeable)
Stealth Black Color Cage
Scattershield
Driveshaft Loop
SS Valve Stems
Completely legal to run 10.0's
5 point Harness
Black Leather Seat Conversion
CF interior trim pieces
Complete Carbon Fiber Front End
Carbon Fiber Trunk
VOLK TE37's, BFG Drag Radials
SS Braided Lines
RnR Spec Coilovers
Clarion DVD in-dash
4 Kenwood Speakers
2 12" Subs, AMP, custom enclosure/easily removeable for racing
This Daily Driven Street Car will easy make 700whp at 35psi
Old May 8, 2006, 03:06 PM
RnR Racing's Avatar
Pics coming soon, I hope.
Old May 8, 2006, 03:12 PM
Ted B's Avatar
With the proper injector driver, the 1000cc injectors would likely have sufficed.
Old May 8, 2006, 03:25 PM
jmartinez1170's Avatar
Sounds good i like the numbers.
But i got a ? so you got the Aeromotive 1000HP Fuel Pump, Aero Regulator
-10 AN Feed line, -8AN Return Line, AN Fittings at all locations . How did you max out at 22psi is it because of the high load the motor can take or displacement. Could you explane a lil more why you hit the wall i thought 1000cc where enough for a 37R.
Sorry for the dumb ?
Old May 8, 2006, 03:29 PM
RnR Racing's Avatar
We thought 1000's would be enough too. There just wasn't anymore room in the software to add fuel. We could play with adding fuel pressure, but it still won't be enough for 750whp.
Old May 8, 2006, 03:33 PM
fsugatorbait's Avatar
Nice numbers, but didnt you say that in your last thread?
Old May 8, 2006, 03:34 PM
Now i see why you need the injector driver box. Well besides trying to get your car to idel right. 1000cc to 1600cc its like night and day its crazy.
RnR Racing's Avatar
I know we had some downloading issues with the camera. We are working on getting them up as soon as we have some free time.
Old May 8, 2006, 03:38 PM
Big Boost's Avatar
Hey Ryan,
Can you post a dyno chart? I would like to see the curve with a 2.4 & a 37R. Also do you have some of the AEM logs you could post?
I am sure a bunch of guys would love to see at what RPM you are achieveing full boost by with the set-up.
Thanks-Big Boost
Old May 8, 2006, 03:44 PM
RnR Racing's Avatar
Ya, when I go back there this week I will get the old sheets and the new ones when we tune it again.
Old May 8, 2006, 04:03 PM
EvoRecordSetter's Avatar
560whp and 481ft lbs at 22psi
welp theres my goal lol... id be happy with that.
could you get that on pump gas? 22 psi isnt that much :P
Dyno CHArTS ASAP =)!
Old May 8, 2006, 04:25 PM
RnR Racing's Avatar
Ya, TT has the dyno charts. I will get them this week unless they post them up sooner.
Old May 8, 2006, 04:47 PM
Ted B's Avatar
1000cc injectors shouldn't run static until the engine is delivering around 850bhp. The reason why this isn't happening appears to be the AEM injector/driver mismatch, that most likely causes the injectors to open very slowly (not enough current), which effectively reduces the *effective* injector capacity.
I might suggest running the car again with the low impedance injector driver pack installed and denoting the difference in injector duty vs. AFR. Chances are you'll see the AFR go suddenly rich with no other changes to the present map.
Old May 8, 2006, 04:51 PM
RnR Racing's Avatar
Ya, that could be very true. I thought for sure we would have enough injector for 700whp. I know once the 1600's go in we could run into some driveability issues.
Old May 8, 2006, 04:55 PM
Ted B's Avatar
I'd be willing to bet that you'll be fine with the injector driver pack. It would be interesting to see the difference it makes (useful info for every EMS user), and you may not need concern yourself with the huge 1600s after all.
Quick Reply: RnR (Daily Driver) HITS THE DYNO!!!!
