Shipping MR Trans to Shep?
As some of you may have known about my New England Dragway post, I thought my Cusco twin blew out but it was perfectly fine except the $5 part, tin or aluminum circle clip with little claws that goes around the TOB popped off.
I decided it was probably the best thing to happen since it made me have to rip out the tranny, and found nothing wrong but gave me the opportunity to get this and the tcase stronger from Shep.
Anyone send out their MR Trans to shep? He says to use Fedex ground but the MR trans's are definately heavier then the 5speeds, and over the fedex ground limit of 150.
Plus I want to send out the tcase. Even if I seperate it the tranny alone is heavy and to with the dimensions of a box/pickup of 250lbs, 36x18x18 it was like 330 or 380. But the tcase for ground would be 43.
I am not that far away but the freight is what kills it. Has anyone sent out their MR Tranny, and how did they do it?
Thanks
Thanks
Give shep a call i am sure he has got this question thousands of times on a better alternative to FedEx. I know i am making a trip there hopefully next month to get the same work done, but on the 5 speed and a new tcase.
I would go to your local fedex and talk to someone and see if they got any special ways to ship this? As far as size and weight is concerned. Regardless it will be money but you might be able to talk to someone to save you a couple bucks.
And if that doesn't work maybe even driving would be cheaper...
Steve
Steve
Al, Like i said to you when i met you, i trust your choices you make as far as parts are concerned and who to go to. After i heard about your shepard Trans and all of that good stuff i was sold. I will let you know how it is for me, which i am sure will be top notch.
Might even be cheaper to go through the USPS. But idk if they have a weight limit for shipping items
Steve
GnV Motorsports
Steve
GnV Motorsports
Originally Posted by DynoFlash
You all wont be disappointed when you get back the goods from Shep - the guy is a master and the difference is shocking
Yeah my boy over at Z1 told me to use BAX, and Shep said he has heard it is a bit more but he gave me a number to this other place to try out and he said would be under 200 for both. Calling both in a few.
Yeah Al, I can't wait for it. Then all I need is to build my motor up and I am coming for you LOL.
It is cool too that this is on the MR so it costs very little to do the TCase, and the tranny is about the same but much cheaper then the competitors but all the fastest Evos use his. You use the Quaiffe though right Al?
Almost broke my wrist last night putting it in the box though, got pinned against the reinforced box and the bottom of the tranny. Then had the shift linkage rub up my arm.
Originally Posted by Agent-Smith
You will have to use fedex freight. 6-7 day ship times on average.
Please, please don't use brown. They damaged my exhaust over a month and a half ago and I should finally get my new one this week.
Sorry for the highjack back on topic now guys.
Just my .02.
Originally Posted by newbie03evo
Yeah man I work at FedEx in the World Tech Center in Memphis. FedEx Freight is the way to go for this.
Just my .02.
Just my .02.
Anyways. Yes please post the prices, and your opinions on the job, because i am going there soon as well.
Fedex freight unfortunately isn't the way to go. It would cost well over 300 to get these sent out.
So far, GNV I was referred by Adam to check out BAXglobal.com The dimensions of the box i have I believe was 36x18x22 or something and the weight I put was 320 I believe and it came out to 150.
Steve
GnV Motorsports
Good Luck
I'm currently doing the same thing. My car was towed to a shop just yesterday to have the transmission removed to be shipped to john sheppard. i was unaware of the weight being too heavy to send through fedex ground though.
