Very interesting observation on Works 3" 02 housing
I noticed a similar thing about the stock gasket used on the O2 housing as compared to the gasket shipped with the SS auto-chrome (ebay) housing. The stock gasket did not create a seal between the two sections even though the stock housing is divided. The SS auto-chrome gasket was not great quality but it creates a seal on the division line. I find this interesting…
I took the advice from a few folks here and re-used my stock gasket as I was worried that other material may fail (it did seem rather cheap)... If you have done this install you may agree with me in not wanting to have to change that anytime soon!
Anyway, my thoughts were that the stock gasket allows a small amount of flow between the waste gate dump area and the actual turbo exhaust outlet. Anyone else notice/consider this with the stock setup???
I would suspect there is some turbulence created here, but I trusted Mitsu on this (not being an automotive engineer myself) and figured using stock gasket would do the same with the SS housing as it did with the stock 02 housing so I ground it a tad to fit and re-used it...
I think the Works part looks really nice, I bet there are good gains with it. Seems like the Works housing follows the stock gasket form at least!
I would love to hear from David and others as to why the stock gasket is like when both parts being joined are divided...
Thanks!
Thanks!
I have had the Works on my car for over a year now. I have talked to some people on the divorced vs. open design. When you're at WOT, how open is the wastegate? When you're running almost 20 psi stock, what percentage of the time do you think the wastegate spends open? That's the question you need to ask yourself. I think it comes down to theory vs application. Regardless of what you believe, the opening to the downpipe of the Works is still the biggest on the market.
Actually, the wastegate flow isn't the issue, it's the flow from the turbine. The idea is to not have a rough transition for the exhaust once it exits the wheel so as to not stall the airflow.
This is old news. Id love to see a Works vs. Invidia test done. My money would be on the Invidia piece because of the seperation and previous tests showing no gains between a 2.5" and 3.0" ID o2 housing.
Originally Posted by kimletrim
Also notice that WORKS doesn't have any dyno numbers with their O2 housing despite all the R&D they did.
Precisely. They talked it up pretty good, but never posted the numbers. I wonder why?
I don't think I have seen much in terms of dyno sheets from them on any of their parts, just estimations. I have some Works parts and they seem to be good quality and work well for what they are (air filter and t-body).
Good point on the dyno thing, not sure why anyone would do all that R&D and not have the numbers. They must have tested this and have numbers… Maybe it's just too subjective to post public figures in their opinion? Not defending, just seen too many vendors that have posted dyno “proof” get slammed here…
SOme people on this board have nothing better to do that throw crap around and hope it sticks. Get a life.
WORKS is one of the many great Vendors
available in the Evo community. Obviously there are many choices.
I'm willing to put the WORKS O2 housing
on my Evo, along with a setup similar to thier TR340 package.
My needs are a reliability, longevity, stealth and the ability to pass California emissions.
If I can get a realistic daily driven 280 to 300 awhp, Then I can call it a day.
That's right. Works has built their reputation on being shady and underhanded
Where in the world did you get shady and underhanded from what I said? Maybe you should get off their nuts and learn some reading comprehension. I stated facts- period. Unless you know about some super secret dyno charts that no one else does, shush.
