Anyone with an Aeromotive A1000 fuel pump?
Originally Posted by ExViTermini
did you just connect a line from the tank outlet to the aeromotive pump or did you use the in-tank pump as a feed pump to the aeromotive?
btw you plan on doing a write up on this?
Wait a min are you still running the stock tank i tought you made a tank. And are you useing this as a second pump or as one becasue in the picture looks like your running both.
My fuel setup goes as follows.
I plumbed off the backs of the saddles. I choose to keep the stock tank so that I'm not put into a different class if I choose to race.
Both these feeds connect to a Y block that then feeds into the pump.
The pump feeds into a fuel filter
The filter connects to a -8 line which feeds directly to the fuel rail feeding 95# injectimicators. The pressure is built using an SX FPR.
After the FPR, the fuel is sent back to the pump via a -6 line. The fuel returns to the tank via the stock fuel pump OUTLET.
Originally Posted by bolsen
Trina, did you ever get rubber bushings for the mounts? Any difference?
