WHP limits of Walbro 255
Originally Posted by kjewer1
Assuming fuel specific gravity of .724 (sunoco 117), target AFR of 12:1, and boost of 30 psi and base of 43 psi, the 255 LP supports 57 lbs/min, and the 255HP supports 68 lbs/min. The 35r will do ~65 lbs/min for most poeple. The HP version should do much better.
You can use a 255 as a lift pump to feed a Aeromotive A1000 or similar, but there are some funny things that go on. Fine for a WOT race car, but idle and cruise will cause some starvation of the A1000 and shorten it's life (people already have trouble getting that pump to last in street cars). One or two 255s feeding a low pressure swirl pot might keep a A1000 fed, but no one I know has tried this either.
FS[SouthEast]: Walbro 255
hutch959
Aug 18, 2016 04:23 PM
hutch959
Dec 18, 2015 05:20 PM
archie001
77
Nov 11, 2004 07:24 AM
Megadeth2118
Lancer Aftermarket Forced Induction Tech
Nov 1, 2004 02:36 AM
