My Car Died
Old May 20, 2006 | 04:57 PM
EvoVIII_MR2005's Avatar
Check your IC pipes and then reset your ECU.
Old May 20, 2006 | 06:17 PM
Eggy's Avatar
check baterry connections!!!
This happened to me and all it was was a loose connection on the negative terminal >.<
Old May 20, 2006 | 06:27 PM
boostedwrx's Avatar
let us know what happened when you figure it out
Old May 20, 2006 | 06:50 PM
EvoHung's Avatar
Fuses, spark plug, and connections
Old May 20, 2006 | 08:25 PM
PEOPLExpress's Avatar
I totally blew a fuse......
Old May 21, 2006 | 01:44 AM
NvsEvo's Avatar
i knew it......it was because your o2 sensor in your test pipe got fried huh!?!
The same thing happened to me a while back
Old May 21, 2006 | 01:18 PM
if i fired my 02 sensor, would there be some kind of check engine light?
Old May 21, 2006 | 04:59 PM
car keeps dying.....this sucks
Old May 21, 2006 | 05:43 PM
ne body, please help
Old May 21, 2006 | 05:52 PM
Silk's Avatar
Check your cam position sensor, i accidently broke mine when i put my intake on. Car would turn over and run briefly but just die then.
Old May 21, 2006 | 06:01 PM
smokedmustang's Avatar
You checked all your IC hoses on not?
Old May 21, 2006 | 06:41 PM
all the IC piping looks good, i just keep blowing fuses. I cleaned my intake a couple months ago......
Old May 21, 2006 | 08:22 PM
11secEVO7's Avatar
i'm betting crank angle sensor
happened to me already and those were the symptoms
Old May 22, 2006 | 06:03 AM
how can i check that????
Old May 22, 2006 | 06:08 AM
AndyBandy's Avatar
Check your o2 sensor housing on your exhaust near the test pipe. When I installed my HKS TBE, the o2 sensor wires were rubbing on the exhaust shield underneath the car and grounded out numerous times. I just put some heat resistant silicon on the exposed wires and dented back the exhaust shield so it wouldn’t rub anymore. This fuse I believe is in the #8 slot under the hood, it’s a 20 amp fuse. If that’s the one that keeps blowing, this could be your problem. Any other questions, feel free to ask.
Oh and this problem if diagnosed by a shop through a machine will tell you it’s the crankshaft sensor, but my problem turned out to be this wire grounding out.
