My Car Died
Old May 22, 2006 | 07:12 AM
  #31
11secEVO7's Avatar
reason i said crank angle sensor is because mine burned out under the same type of driving etc......you can get a mechanic to check it out easily....it's a sensor behind the driver's side front wheel..down by the big crank bolt there.
Old May 23, 2006 | 08:38 PM
  #32
IslandEvoIX's Avatar
ok what fuse r u blowing? i had this same problem and i think i know whats wrong. check to make sure that ur o2 sensor is not rubbing up against ur half shaft. i didnt pay attention when i did my tbe install and my half shaft frayed the wires causing them to ground out against the half shaft and blow the fuse. if ur blowing the engine control fuse in the engine bay i believe number 8 thats ur problem.
Old May 24, 2006 | 03:43 AM
  #33
AndyBandy's Avatar
yes islandevoix, thats the similar problem i explained.
any updates?????
Old May 26, 2006 | 10:32 AM
  #34
PEOPLExpress's Avatar
so what happened was my o2 sensor was shorting out, prob rubbing against something, i did the quick fix not to throw a CEL. I took them out and my car has ran fine. There was even an exhaust rattle before i took them out, and now its totally gone. My CEL light is on, but i dont care at this point. Just put my Downpipe in too, WOW.....it is great to have the car running again.......THNX FOR ALL YOUR HELP GUYS
Old May 26, 2006 | 10:39 AM
  #35
fsugatorbait's Avatar
Tell me you didnt take the front o2 sensor out?
Old May 30, 2006 | 06:29 AM
  #36
no, why would i do that
