Fresh install: Short wirte up on the Buschur 3065
Old Aug 28, 2006, 08:55 PM
  #91
Batmann!'s Avatar
Originally Posted by davidbuschur
Our turbo kits will not clear some of the thicker aftermarket radiators. Sorry it too so long for one of use to answer that question.
The stock radiator has a lot of room. We use to use a Vband flange at the outlet of the turbo to the wastegate, some guys did not adjust that correctly or didn't tighten it enough and ended up with a problem. Now the outlet of the turbo to the wastegate is solid. The closest part of our kit to any radiator is the top of the wastegate. As I say, stock radiator there is quite a bit of extra room. Some thicker aftermarket radiators it is tight though.
Jarrod's car ran 11.04 at 128 mph with this turbo on C16 at 28 psi of boost. Jarrod's car is just our Stages 1-4, AEM EMS, Exedy Twin disc. Still has a bone stock head, shortblock, intake manifold and throttle body on it. Also has HKS 272 cams in it. It is not lightened at all.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxx
What kind of power will this kit make on just pump gas? Also, how would you compare the spool characteristics with that of a 50 trim BB on a 2.0?
Old Aug 28, 2006, 09:01 PM
  #92
Stinkapuss's Avatar
Not that I'm a model for this turbo but so far I made 378whp@ 23 psi with 93 oct and 436whp with 116 @ 30 psi. This is with ecuflash, basic bolt-ons and a blown headgasket.
Old Aug 28, 2006, 09:35 PM
  #93
Nez136's Avatar
These numbers are on pump gas ONLY! I do not have a scanner but as soon as i can get my hands on one i'll post the sheet. I do plan on running a alky injection kit with a AEM. Switching to a AEM alone will unlock a decent amount of power even on pump. It does appear that this is a race gas turbo but it is still fun as hell with pump on the street.
I'll keep everyone updated...
Old Aug 29, 2006, 01:50 AM
  #94
Ang Wen Yan's Avatar
Look like GT3065 is a great turbo
Old Aug 29, 2006, 05:23 AM
  #95
dryad001's Avatar
Pfft, screw race gas Ryan. I'll never run it in my car again. 2 o2 sensors down the tubes. Ill give you a call later on today. See ya friend.
Old Aug 29, 2006, 08:12 AM
  #96
Nez136's Avatar
Aren't you working 3rd shift?? wtf are you doing up?
Im just curious if meth injection will be able to keep up at 32 psi...you would know more about that than me at this point.
Old Aug 29, 2006, 09:03 AM
  #97
Jeff_Jeske's Avatar
In the last year, I've run about 100 gallons of leaded 110 through my EVO and haven't had any problems. Still on the stock O2 sensor and still getting 28MPG.
Old Sep 5, 2006, 05:38 AM
  #98
Stinkapuss's Avatar
I just ran 11.26 @ 127 with this turbo and ecuflash so that's something for you guys to look forward to.
Old Sep 5, 2006, 07:52 AM
  #99
David Buschur's Avatar
stinkapuss,
Very nice times. Is that with our kit? What fuel were you running?
Old Sep 5, 2006, 08:43 AM
  #100
Stinkapuss's Avatar
stinkapuss,
Yes, it was with your kit and torco 116 octane. This turbo rocks! The spool up between shifts is sick!
Heres my thread in the drag forum.
https://www.evolutionm.net/forums/sh...d.php?t=221485
Old Sep 5, 2006, 08:51 AM
  #101
dryad001's Avatar
Good time. Im looking forward to hitting the track soon with my tune.
Old Sep 5, 2006, 09:37 AM
  #102
Nez136's Avatar
I might have to just try cranking the boost up to 27 or so with this tune until i get a race map...
Old Sep 5, 2006, 10:26 AM
  #103
kmcconn9's Avatar
/\ just put in some 116, and crank the boost up....if the tune was done correctly it shouldnt need to be changed for the race gas map...
You could adjust the tune for even more power...but you will be safe with your current tune..
Old Sep 5, 2006, 10:37 AM
  #104
Nez136's Avatar
okie dokie
Jameson_IXMR
21
Dec 11, 2016 07:33 PM
Duo Maxwell
For Sale - Cars For Sale
Mar 29, 2013 09:13 AM
HaVoC RR
Northeast Region
10
Aug 11, 2008 11:30 AM
SIMSSEGA
Lancer Aftermarket Forced Induction Tech
57
Nov 12, 2006 08:01 PM
Quick Reply: Fresh install: Short wirte up on the Buschur 3065
