Best 750cc injectors to run off of stock ecu??
I was looking at the FIC injectors from what ive found a couple people use them with no problems... anyone else suggest anything else??
I am assuming that you will be using a flash to scale the injectors?
You can put the injectors in on the stock ECU as long as they are low impedance. Your car will idle and it will run...it will drive like poop though.
