Exedy twin howl/whine when clutch engages
Old Jun 28, 2006 | 08:30 AM
TonyG's Avatar
I just got the twin HD installed, and I'm still breaking it in (about 400 miles so far). I'm hearing two different types of noises -I think one of them is normal, but I'm not sure about the other one, and would like to hear some experienced opinions.
The first noise is a little chatter when I release/disengage the clutch while shifting. I think is completely normal.
The other noise is a loud momentary whine or howl at the moment the clutch grabs as I'm raising the clutch pedal. It only happens when the clutch engages a little harder than normal. For example, it happens when I downshift, or when I'm stopped on a hill and then proceed to go. If I rev match while down shifting, or upshift nice and easy, it doesn't happen. But if I upshift a little harder than normal, it will happen. I haven't launched on the new clutch yet, but I'm sure it will happen then too.
Can anyone with an exedy twin disk chime in?
Old Jun 28, 2006 | 09:07 AM
evodrivesme's Avatar
my tilton dual cerametalic makes a whine noise when im slowing down and let the clutch out, its a pretty normal thing with big aftermarket clutchs.
Old Jun 28, 2006 | 09:11 AM
Nez136's Avatar
My HD twin does the same thing. When launching it goes away
Old Jun 28, 2006 | 09:59 AM
itzwolf's Avatar
I get some light decel chatter on my exedy twin hd, but otherwise my clutch is very quiet. Second twin disk I've owned (Cusco being the first which had the same decel chatter).
Old Jun 28, 2006 | 10:05 AM
Rez90's Avatar
the twin disc i used to have did that. From what i understand it's pretty normal.
Old Jun 28, 2006 | 10:06 AM
freshevo8's Avatar
same noise here. my friends 9 MR doesnt do it though and he has the HD also.
Old Jun 28, 2006 | 10:07 AM
Event-Horizon's Avatar
The howl is normal. My HD does it occasionally. It seems to go away with the more mileage I am putting on it. That or I could be getting used to the engagement. I've noticed your seating position is important when dealing with this clutch. I would try different positions in the seat to you feel combatable with the engagement. Also, the more you let it slip the more noise it will make.
Old Jun 28, 2006 | 12:58 PM
supeazn's Avatar
i'm getting the same kind of noises, but there's another one .... the turbo spool sounds way different... the blow-off sounds like its choking or something... did anyone else get this after installing their HD????? Need HELP!!!
Old Jun 28, 2006 | 02:39 PM
TonyG's Avatar
I hear that sometimes when I shift gears, but I thought it's just the chatter/rattle noise happening in sync with the blow off. Yeah, it sounds like a sick BOV, but I think its just mechanical noise from the clutch.
Old Jun 28, 2006 | 02:43 PM
bluebyu36's Avatar
my 4th gear only whistles?what the hell is that i have exedy and i get the dec.noise to
Old Jun 28, 2006 | 03:02 PM
dryad001's Avatar
Hmm, you should hear a tilton decel noise. Kinda sounds like the tranny is going to fall out. Annoying yes, but funny at the same time. Let off the gas next to someone with their windows down and look at their face.
Old Jun 28, 2006 | 04:51 PM
03EVO583's Avatar
The noise is most likely gear lash in the transmisison during the deceleration. The lower inertia clutch is probably causing it and creating the increased noise. The 6-spd in the MR may not have as much gear lash as the 5-spd, and may be why it is not heard.
Old Jun 28, 2006 | 05:36 PM
EVOlutionary's Avatar
Completely normal. Did it on my ETD and my buddies ETD HD. It seems like it is part of the break-in. After about 1000 to 2000 it will go away. Also, do a couple hard launches and it will go away. If you drive really soft for a long time it will come back a little bit. Might have to do with the way the clutch disc material gets worn or glazed. . .
Old Jun 28, 2006 | 07:32 PM
silverofs's Avatar
i have the same noise.... goes away after launching but comes back a few weeks later.....
(exedy twin)
Old Jun 28, 2006 | 07:36 PM
j-evo8's Avatar
I have the same noise on my Exedy Twin disc. Funny thing is that it did it with the stock clutch too (reason why I replaced it with a twin disc at 9k). I now have 31k on my car and the noise is still there.
I do agree, if I try and launch the car, the noise goes away for a day or so, then comes back. My Ignalls Stiffy helped lessed the noise just a little.
I'm just taking it as normal.
Quick Reply: Exedy twin howl/whine when clutch engages
