8 psi max on a stock ix!
Originally Posted by Roberto
The title of this thread you started stated that the Evo was stock. Now, you post that the car had an HKS BOV and Blitz boost controller on it for at least two months before the problem started. This is far from a stock Evo, and I call BS on it that your stock ECU was causing the problem.
I think some of you guys are screwing up your car with bad or incorrectly installed mods, and are not fessing up.
I say take off the crappy, flakey boost controller, ditch the riceboi blow off valve, install the stock diverter valve, a decent manual boost controller (bypassing the stock boost solenoid), then check the wastegate and all vacuum hoses. You'll get your boost back without some retard changing your ECU.
Thanks
Originally Posted by 3000ways
I don't know, I've never had that issue, and just because your car is stock now, doesn't mean a problem couldn't have occured while it wasn't stock. Also I don't think that the IX is more problematic than any other EVO models, it's just that there seem to be so many new and fresh faces buying IXs, unlike VIIIs that were bought a lot by former DSMers and others with experience with turbo and AWD cars. This does not seem to be the case with the IX. Just look at some of the questions being asked by new IX owners, I mean somebody asked why there is a bigger space inbetween 70 and 75 mph in speedo, WTF!
i had a problem with my VIII only boosting 12psi (which is wastegate spring pressure) and tried everything on earth (except a new ecu) to figure out the problem and nothing ever worked. I had MINIMAL mods (Works flash and samco hoses with a Blitz DCII turbo timer/boost guage). I finally "solved"/band-aided the problem by throwing an MBC on and cranking it down to 1.4bar.
probably some freak issue with random ecu's or something.
SOG RA
34
Sep 17, 2015 10:14 PM
