Problem with HKS GD Pro clutch
Hello,
is there anyone else using this clutch ?
I have some problems when downshifting in lower gears... from 3rd to 2nd and from 2nd to 1st gear...
and it's not a gearbox issue...
The problem I have is that after downshifting, even if I release the clutch pedal very very slooooowly, i get instant and brutal clutch engagement.... no way to modulate the engagement...
I already changed engine bushings but that didn't made a real difference.... only a bit better.
TIA.
Bye...
TIA.
Bye...
uuhhh, i think thats normal. thats what all 6 puck style ceramic discs exhibit. i installed this hks clutch for a friend, and its more like an on or off engagment, no inbetween.
Yes sgevotx...
I perfectly understand what you mean.... it seems to be the only solution !!!
But I still don't understand why it has this problem sometimes, and not always, and especially with hot engine !!!
Bah....
in my case I have zero problem starting or upshifting and engage... it's even quite soft and with a good modulation !
Problem is only when downshifting and engage in lower gears...
CeliOnce
Feb 15, 2017 04:56 PM
Illumin8
Feb 8, 2017 05:50 AM
millsyy17
17
Sep 5, 2011 12:22 PM
